Canada,,,,,,,,,then you are up by my Buddy, M1Dadio,,,,,,,do you ever go over to his Island,,,,,and you got Twin Pilot and Kooky Krispy to the South of you,,,,,,,now I'm ready to work,,,,,,,,I would say the front metal cartridges in a 1st Gen, 1964-66, are 1 1/8" in diameter,,,,with 2" wide springs,,,with a 9/16" bolt through them,,,,,2nd Gens, 1967-70, use a 1/2" bolt through their 3" springs,,, but you never know what you will find on the vans now,,,,,,The shackles are plain old rubber,,,,,now the fronts have a metal cartridge,,,you might be able to find one,,,,but my spring shop went out of business and we are looking for those #2056 polyurethane bushings and the sleeves to go in instead of those metal ones,,,,,I have seen 1 1/8" fronts on the drivers side and 1 1/2" on the fronts of the passenger springs,,,,you just have to see what you find and when we get on the same page, you will get a good answer,,,,,,and it usually takes me a couple of questions and answers to dial in to your problem, so dont expect a real fast answer,,,,,the longer I take, the better the answer I can give,,,,,,
