    Leaf spring bushings???
    1-star
    1-star
    Number of posts : 25
    Registration date : 2014-12-03
    Leaf spring bushings??? Empty Leaf spring bushings???
    Post by 1-star Tue Sep 01, 2015 8:38 am
    Help.
    1. I'm not great with mechanics.
    2. I'm in the UK.
    Can someone link me up with the correct bushings for my front leaf springs as mine are clonking like a bastard at the moment....metal on metal!
    Cheers in advance.
    Gary.
    Number of posts : 12234
    Leaf spring bushings??? Empty Re: Leaf spring bushings???
    Post by donivan65 Tue Sep 01, 2015 9:56 am
    do you have this set up,,,,,,,,rubber bushings for the rear of the springs in the shackle,,,,,,,and a metal cartridge in the front end that sits in the perch? which do you need? This is what a Chevy would use,,,,,,,
    Leaf spring bushings??? Spring10
    1-star
    1-star
    Post by 1-star Tue Sep 01, 2015 10:45 am
    Not sure to be honest man, I'll have a look.
    Post by donivan65 Tue Sep 01, 2015 12:29 pm
    do what you can,,,,,,we got to start somewhere,,,,,,,the more information we get, the better chance of you getting a good answer,,,,,,,,you can take a jack, remove the bolt and push the spring down to look at and repair the bushings,,,,,,do you think it is the front one that is going bad?
    Leaf spring bushings??? Repair14
    1-star
    1-star
    Post by 1-star Tue Sep 01, 2015 11:30 pm
    Yes, doesn't appear to be any rubber left on the front.
    Post by donivan65 Wed Sep 02, 2015 9:33 am
    Changing those metal cartridges aint easy,,,,,,,,you need special tools,,,,,,but lets hear from some Dodge guys if they know where to get those cartridges or the polyurethane ones ,,,,,,,,,,,
    Leaf spring bushings??? Repair15
    Leaf spring bushings??? Repair16
    Number of posts : 8759
    Post by dix Wed Sep 02, 2015 2:40 pm
    Donnie that is a road i have not gone down yet, i'm not sure where to get them ,
    but there is tons of suppliers . once they get one out it should be the same on all corners. hope some one chimes in that did them.
    Post by donivan65 Wed Sep 02, 2015 2:43 pm
    ,,,just looking at Oreileys Auto parts for a 65,,,,,,,,I see stuff,,,,,,,maybe front and rear are different sizes or different GVWs,,,,,
    http://www.oreillyauto.com/site/c/search/Leaf+Spring+Shackle+Bushing/03964/C0361.oap?model=A100&vi=5156621&year=1965&make=Dodge
    1-star
    1-star
    Post by 1-star Thu Sep 03, 2015 1:05 am
    Apparently these guys are pretty good for bushings...
    http://www.springsnthings.com
    Post by donivan65 Thu Sep 03, 2015 10:12 am
    There you go, you got some good information now on what needs to be done,,,,,,,,,,,so whats your plan,,,,,,,,can you find a shop that will work on your van in the Motherland,,,,,,,,,,,,,,,,
    busman78
    busman78
    Number of posts : 483
    Post by busman78 Thu Sep 03, 2015 3:36 pm
    Here are two businesses I know have the right bushings
    McVeigh Truck Springs - www.mcveightrucksprings.com
    located Milo, MI  989-826-3682
    Atlas Spring & Axle - www.atlasspringandaxle.com
    located Wichita, KS 316-943-2386
    Have purchased bushings from McVeigh on several occasions and Atlas Spring just made me new rear springs, so both can supply your needs.
    Any suspension shop in your area should be able to pull the bushings, they may even have some that will fit, British Standard sizing is not that much different from SAE.
    Use this tool for removing and installing bushings, just a length of 1/2" all thread, some washers, couple nuts and sockets that will fit the bushing, missing is the short piece of pipe for pulling but you should get the idea.
    Leaf spring bushings??? Bushin10
      Current date/time is Thu Sep 19, 2024 12:33 am
