erodstrom
rustytoolss
    Rubber mat patten or template
    rustytoolss
    rustytoolss
    Number of posts : 624
    Rubber mat patten or template Empty Rubber mat patten or template
    Post by rustytoolss Mon Jun 22, 2015 9:16 am
    I d not have the front rubber floor mat in my pickup. I an buy rubber material from home depot. Does anyone have a pattern or template, or even a good diagram ( with dimensions), for the front rubber floor mat ?
    rustytoolss
    rustytoolss
    Rubber mat patten or template Empty Re: Rubber mat patten or template
    Post by rustytoolss Mon Jun 22, 2015 9:19 am
    see above
    erodstrom
    erodstrom
    Number of posts : 28
    Registration date : 2011-09-22
    Post by erodstrom Sun Jul 12, 2015 4:55 pm
    I think my van still has the intact mat, it's on the list to pull it and clean it and inspect underneath. Might take me a month or so to get there, but I could measure/trace for you once I do if no one has it handy.
    rustytoolss
    rustytoolss
    Post by rustytoolss Sun Jul 12, 2015 6:17 pm
    erodstrom wrote:I think my van still has the intact mat, it's on the list to pull it and clean it and inspect underneath. Might take me a month or so to get there, but I could measure/trace for you once I do if no one has it handy.
    Thanks, Since I do not have anything on my floor, that would help me a bunch.
    erodstrom
    erodstrom
    Post by erodstrom Sun Jul 12, 2015 6:56 pm
    Ok, I'll look at it this week. Mine has an AC unit that looks like it is bolted in right over the mat, so it might be a bit of a process to get it out. If I can pull it out around everything, i'll do it right away.
    rustytoolss
    rustytoolss
    Post by rustytoolss Mon Aug 03, 2015 7:42 am
    erodstrom wrote:Ok, I'll look at it this week. Mine has an AC unit that looks like it is bolted in right over the mat, so it might be a bit of a process to get it out. If I can pull it out around everything, i'll do it right away.
    Did you happen to remove your floor mat, yet ?
    erodstrom
    erodstrom
    Post by erodstrom Mon Aug 03, 2015 8:41 am
    Hi there, I'm actually getting close. Looks like either I cut it out to get around the A/C unit or I remove the AC, and I've been stalling the decision..
    rustytoolss
    rustytoolss
    Post by rustytoolss Mon Aug 03, 2015 9:03 am
    Just thought that I would keep in touch. Thanks
    erodstrom
    erodstrom
    Post by erodstrom Mon Aug 03, 2015 11:07 am
    I cleaned my way down to it this weekend, but ran out of time after pulling the rear floor. Hopefully soon, it's the final stinky part of my interior!
    bigdougalas
    bigdougalas
    Number of posts : 81
    Registration date : 2015-06-02
    Rubber mat patten or template Empty rubber mat pattern
    Post by bigdougalas Mon Aug 03, 2015 1:38 pm
    If you can make a pattern I would like one also as lonk as you work cheap Thanks
    erodstrom
    erodstrom
    Post by erodstrom Mon Aug 03, 2015 2:39 pm
    Sure, I figured I'd trace it onto something and mail it, no big deal!
    rustytoolss
    rustytoolss
    Post by rustytoolss Mon Aug 03, 2015 3:03 pm
    Sounds great to me. I will send a PM with my info. Thanks so much.
    Number of posts : 1686
    Post by westcoastvanner Wed Aug 12, 2015 2:19 pm
    Number of posts : 14778
    Post by vanny Wed Aug 12, 2015 2:30 pm
    That's a great buy!
    Number of posts : 1569
    Post by OutofSight Fri Nov 20, 2015 5:30 pm
    Some sent me a pattern years ago and it was a nice fit. I recently found an nos one and it is a much nicer fit.
      Current date/time is Sat Jan 25, 2025 10:11 pm
