Has anyone ever had tranny fluid come out of the dipstick tube from the motor overheating?
I have a 250 cu in motor with the c4 auto trans and if I go on the freeway or drive more than 15 minutes I noticed that trans fluid has burped out of the dipstick tube onto my exhaust and starter. I noticed my motor's temp was over 200 degrees when this happened. I started the truck the other day took the radiator cap off and noticed there is no flow of fluid in the radiator so Im thinking its either a thermostat and or a water pump. Please weigh in if anyone has experienced this.
Thanks
Thanks
