Today I decided to replace the + and - batter cables. While digging into it I also decided to change out the starter relay (I know, if its not broke, dont fix it) and after buttoning it all abck up, the blody 318 wont start. It will turn over and crank but no ignition. I replace the starter relay with a NAPA relay (looks the same only cleaner ;-)
I suspect its the relay, but is there anything I am missing.
I have properly put the + batter lead to the relay, and the other wire that goes to the statrer and the correct wire that runs up to the ammeter.
Any ideas or suggestions before I rip out the brand new shiny starter relay and put the OEM one from 1969 back on it?
