by blackace Fri Aug 03, 2012 10:51 am
OK this is really a pain in the @s@. Here are the things that I have done and still sitting where with none functioning horns. What I started with was just a clicking sound of the relay, which is under the dash, when the horn switch on the steering wheel is pushed down.
1) take old horns off and remove the tone screw and soak the insides with PB Blaster, hitting them with a rubber mallet and also with an alum bar. (trying to break loose diaphram or moving parts)
2) tested on a spare battery, negative to mounting bracket and positive to post on horn. (No sound)
3) bought another set of vintage horns that were to be a working set and put on truck with same results as original horns (just clicking of relay). soaked and roughed them up also with no change in success
4) Checked the fuse. (Good)
5) Pulled relay and tested with a continutanty meter. Had it through the contacts between the horn switch in the steering wheel and the contact for the fuse box wire.
6) Tested all horns with battery charger with negative onto the mounting bracket and positive on terminal. (Nothing out of any horn, even after abusing them a bit more with the rubber mallet)
7) Went out and bought a new horn, tested it at the part store, installed on truck with ground wire between body and new horn and still only get a clicking of the relay.
At that point I gave up and had to get back to work as I was already 30 min late for lunch hr.
Tonight I am going to run a wire from the negative side of the battery to the mounting stud of the new horn to by pass any grounding issues to see if it works.
Does anyone have any other ideas as to what to try. I have been cussing on this and usualy that would be bleeped out by a horn noise but, well you know that situation.
