Hey, I was trying to install a wireless backup light camera/monitor kit on my '67 108 the other week, and found that the voltage on the backup lights has quite a drop. That I upgraded the backup lights to about 70 or 80 watts load might have something to do with it. But there's a 10 amp fuse on that circuit so it should be able to handle even the upgraded bulbs.
With the more powerful backup lights installed, the voltage drops to about 8 or 9 volts.
So... I'm wondering if there is a current leak to ground somewhere in that backup light power circuit. As far as I can tell from the service manual, on this van the backup light switch is on the transmission. And the wiring harness for the backup lights (as well as the stop/signal/license lights) looks pretty small gauge.
I checked the resistivity of the circuit with the fuse removed, light bulbs disconected, and with the backup switch engaged (column shifter in reverse), there's a 140 ohm resistance to ground. There should be infinite resistance! So I'm thinking there must be a current leak to ground that is dropping the voltage.
I suppose I could run a separate power wire to the backup switch, and a new power wire from there to the backup lights. It would be a lot of cutting and splicing though, and sort of pointless if the source of the leak is in the switch itself. Pulling the switch itself looks a bit involved from the service manual, and of course it's gonna be a dirty greasy job. But do-able with enough time and patience. And I'm wondering if this backup switch is even available any more (Saginaw manual 3 speed tranny).
Anybody else experience this sort of problem? The backup camera won't work properly with the existing voltage drop. An alternative is to wire the camera and monitor separately with a toggle switch at the dash... but that sort of obviates the whole "camera automatically goes on when the vehicle is put into reverse" concept. And it does bother me that there may be that much of a current leak going on, so I figure I need to fix the backup circuit anyway.
