    Smoothing Body Seams
    Number of posts : 2067
    Smoothing Body Seams Empty Smoothing Body Seams
    Post by sasktrini Mon Jun 02, 2008 8:54 am
    I would like to shave or smooth out the seams between all the exterior side body panels... what's the way to do it?
    I have noticed the panel flanges in the walls have rust (like a lot of the van!), but I assume they provide rigidity for the panels... prevent them from flopping around under turbulence. But back to the topic, is this a bondo job, or do I get to run tack welds to fill the seams?
    Thanx
    Smoothing Body Seams Empty Re: Smoothing Body Seams
    Post by sasktrini Tue Jun 03, 2008 9:00 am
    Or is it an illusion that the seams are filled, because of the paint job quality? For example (Mike), I thought Vanishing Breed had invisible seams...
      Current date/time is Fri Nov 22, 2024 9:18 pm
