Got a question for you.
When you have rear windows that you can open in a Dodge A then can you drive the van while them being open? Or are the exhaust fumes coming in? Or do they vent the air inside to outside and keep the air fresh?
My exhaust ends to the side before the rear wheel and in the beginning I had problems with the fumes coming in. Then my exhaust tip was underneath the van in the middle facing down. Insulating the rear door lower lock holes cured the problem but it could still be better. Now the air inside the van is ok but could be a little better. This is also why I modified the underneath exhaust to side exhaust.
I don't have rear windows that open now. Mine are original fixed. I'm just wondering if I were able to find all related parts to make my rear windows open then would it be better or worse fumewize?
