anyone knows a way to put back thoses rear windows weatherstrips easily? my rubbers are new and stiff....thanks
slowflapper- Number of posts : 957
Re: rear windows weatherstrips
Work from the inside of the door and make sure the rubber is warm so its more pliable.
When I took my windows out I actually took the windows and gaskets out as one piece. Maybe if you put the gasket on the window and then put the whole thing in the frame at once it will be easier?
- Number of posts : 12246
yep, that is how I’ve always done it. also used that method on old bmw and porsche cars as well. we use lots of dish wash detergent, like dawn.
and I use a plastic coated electrical cord. the wife and I recently replaced four gaskets, took us about 5 mins per window and no cussing at each other at all. that’s not the case when I ask her to spot me when backing up the trailer...
so working from inside with electrical cord with alot of soap or something realy greasy and wife pushing(in a good mood )..yeah its noted...appreciated ..corrosive101
