    1968 G10 Chevy Van front wheel bearings Question......
    1968 G10 Chevy Van front wheel bearings  Question...... Empty 1968 G10 Chevy Van front wheel bearings Question......
    Post by Guest Fri Jan 24, 2014 10:17 pm
    Question........
    Will a set of 1968 G10 CHEVY VAN front wheel bearings fit on a 1968 GMC HANDI VAN?
    Are they the same size?
    Thanks.
    Number of posts : 12245
    1968 G10 Chevy Van front wheel bearings  Question...... Empty Re: 1968 G10 Chevy Van front wheel bearings Question......
    Post by donivan65 Sat Jan 25, 2014 8:15 am
    The 1/2 ton vans ( 5 lugs), take the same,,,,,,set 2 and set 6,,,,,,,,,,however,,,,,seems to me,,,,Autozone sells the only ones MADE IN AMERICA,,,,,,(Timkens)
    Number of posts : 1778
    Post by m1dadio Sun Jan 26, 2014 7:56 am
    I find them to be quite a common bearing
    Here is a sample of the drum brake vehicles that used the same bearings and many of these same vehicles used the same bearings with disc brakes.
    1968 G10 Chevy Van front wheel bearings  Question...... Hubsli10
    The biggest problem is many parts counter people today are like the cash register operators who can't make change for you , they can only give you back what the machine says because they are robots trained to work a computer and they can't think outside of that. they are stuck to their numbering system and unless you give then the exact part number their system uses, they are lost.
    We have a saying for this in Canada.
    Artificial intelligence is no match for natural stupidity.
    When you get an older part guy who can think they can usually find it for you. The many suppliers incorporate the same basic number into their numbering system, Usually they just add prefix to the number where they bought it from. more numbers but usually a letter or two.
    Like the bearings are  a 2 and a 6 so you will find br2, br6 or pbr2, pbr6, or pgbpbr6 and so on.
    The best way to find a part is get the original manufacturers part number right off the part if you can and rum that number in various online search engines. The NAPA site has a great search engine where you enter any number and check the "interchange" box.
    And what Don Said! buy "made in america" ask for the manufacturers name and support our North American economy. Timken or "CR" (Chicago Rawhide)
    Check out NAPA
    http://www.napaonline.com/Catalog/Result.aspx?Ntt%3dfront%2bhweel%2bbearing%26Ntk%3dKeyword%26Nty%3d1%26N%3d599001%2b101970%2b50014%2b2014056
    M1D
    Post by Guest Fri Feb 07, 2014 1:44 pm
    Thanks guys.
    Just wanted to make sure a 68 Chevy G10 van was the same. I bought a whole kit on Ebay thinking I would save money but it turns out it would have been cheaper to buy them from Autozone. Now I just have to figure out how to install them. Never replaced front wheel bearings with drum brakes before.
    Post by Twinpilot001 Fri Feb 07, 2014 2:30 pm
    remember - there is no better than an old parts guy =WITH EXPERIENCE & Books! NAPA =is the best & #1 leader. Here in my area we have pep boys, napa, autozone, car quest,shucks auto & NONE !! = NONE can compare with NAPA!!I use only NAPA! cheers
    Post by m1dadio Fri Feb 07, 2014 7:52 pm
    What Twinpilot said:
    We have a NAPA dealer here with an old guy who kept all the old books instead of throwing them out when computerized parts lists came in.
    He can find anything. Sometimes you don't even give him the car make or model, you show him a part or explain what you need different and he comes out of the back with exactly what I want. just blows me away
    The other day I gave him a sheet metal part number Leadfoot found on an old rocker panel. The company is no longer in business and has sold out to a new company that changed all the part numbers.The NAPA guy phones me back 5 minutes later with three 64 to 70 left side lower body panels in Calgary AB and a right side rocker in Toronto ON.
    I put the word out for a 2nd gen windshield, this guy had me one in an hour, one day away,that I get at cost because the place wants to get rid of old stock.
    Its not that its a NAPA dealer, its the old guy who's been around for years and knows all the who, what, where, when and whys
    Priceless!!
    M1d
    Post by donivan65 Fri Feb 07, 2014 8:35 pm
    Eds-68-Chevy wrote:Thanks guys.
    Well basically,,,,,,,pull the wheel, dust cap, cotter pin,,nut, washer, bearing,,,,,put the nut back on,,,,,,pull the hub off hard,,,,nut pulls the inner bearing and seal out,,,,,clean out inside,,,,,,look for cut outs in drum that let you tap the cups out with a punch,,,,,kind of measure how deep old cups are in,,so you get the new ones down deep enough,,,,,make sure cups are facing out before you hit them back in,,,if you dont have a bearing installer,,,,,grind the old cups down a little so they don't stick in the hub after you use them to pound the new cups in,,,,,
    Post by Guest Fri Feb 07, 2014 10:12 pm
    The Napa's around here are all young kids that don't know anything about vans or cars unless its a Honda civic.
    Thanks for the info donivan65. I don't have to take the brake line off? That was my biggest concern. I don't want to ruin the rubber brake line....I haven't been able to find rubber brake lines or emergency brake lines for my van anywhere. I have all new wheel cylinders, brake lines, and shoes all around but haven't been able to find drums, Rubber brake lines, or emergency brake lines for it.
    Post by donivan65 Fri Feb 07, 2014 11:22 pm
    Chevys are easy,,,,,,,pull the wheel and drum off,,,,the nut holds this hub on,,,knock out the cups,,,,hammer the new ones in,,,,,,the brake hoses and drums are still available,,,,,or we use the universal braided hoses when we want to show off,,,,,I kinda think Napa aint got American bearings,,,,
    1968 G10 Chevy Van front wheel bearings  Question...... Hubzli10
    1968 G10 Chevy Van front wheel bearings  Question...... Hublis10
    Post by donivan65 Fri Feb 07, 2014 11:25 pm
    Post by donivan65 Fri Feb 07, 2014 11:28 pm
    Number of posts : 1868
    Post by HandiVanMan Sun Feb 09, 2014 5:39 pm
    You can buy the oriellys house brand front wheel bearings for around $5-$6 each race included.
    Post by donivan65 Wed Feb 12, 2014 6:03 pm
    You put those $3.89 Chinese bearings from Oreillys on your van and you'll most likely end up looking for new hubs and possibly spindles when they give up,,,,,,,,
    1968 G10 Chevy Van front wheel bearings  Question...... A2_bea10
    Post by HandiVanMan Wed Feb 12, 2014 6:35 pm
    I have been running them for 4 years now with no problem. I just had everything apart a couple of days ago & they still look perfect. They still had plenty of grease in them and I didn't find any wear at all on the spindles. I usually pull them once a year and re pack the bearings.
    Post by donivan65 Wed Feb 12, 2014 9:07 pm
    In my world,,,,,,,they don't hold up.......I have found that the cups spin which ruins the hubs,,,,,or the bearings weld themselves to the spindle and it would not be a happy ending if the wheel locked up going down the road,,,,,,,I only use bearings made in the USA,,,,,,but thats the way it is in my World,,,,,,I am just telling you what I find on these vans,,,,I don't trust those China/Pakistan/Korea/Taiwan bearings,,,,,,but people can make their own decisions,,,,,,,
    Post by m1dadio Wed Feb 12, 2014 9:28 pm
    Make the choice to support your own economy and put your fellow Americans back to work. Buy American Made only!
    Post by donivan65 Wed Feb 12, 2014 10:27 pm
    ,,,,,,,,but it is getting REALLY hard to find bearings made in the USA...............
    Post by HandiVanMan Thu Feb 13, 2014 1:54 am
    These days most of the stuff that you buy that says made in the USA is made in another country and shipped to the USA then final assembly and maybe use 1 part that is actually made here. They then package it and stamp it as made in the USA.
    Post by m1dadio Thu Feb 13, 2014 6:03 am
    Truthfully Made in USA is getting harder to find for sure. I did say "Made in America". Canada and the USA have trade agreements and we respect each others needs and agreements unlike other countries producing stuff cheep (by steeling our technology) and then sell on our markets while continuing  to ignore or manipulate our trade rules.
    It is a fact, since establishing Canada/US trade agreements; Most things made in North America have parts made in both the USA and Canada. This is especially true in the more industrial areas of our Eastern North America. Just look at American made cars as an example.
    In Canada we have laws against false advertising. The packaging of Items sold here, including items from USA companies cannot say Made in USA or Made in Canada if they were not mostly made here (there is a % value American made it has to be). They have to say on the package, "imported for (name of company)" or "Packaged for (name of company"  or "assembled in Canada" or "assembled in USA".
    I don't know how its different in the USA but Canada has Government agencies set up to regulate and control packaging and advertising and they are set up in ways the commercial interests (corporations)  cannot manipulate or influence them. The Canadian Government takes the"Buy American" thing seriously, they even have government TV commercials promoting "buy Canadian" and "Buy American". They get accused of being "anti american" and being "Communists"  and those attack campaigns are driven by corporate interests, many US corporations. All you have to do is follow the news to see your current US government constantly being attacked for what they are trying to fix in the USA and if you look at the attackers, they are other parties "backed by corporate interests" .
    Many USA companies don't sell their products in Canada because they don't want to or can't meet those packaging requirements.
    Its  sad  that so many good things of a life style we are trying to maintain are so easily controlled and manipulated by a drive for profit which benefit so few people while damaging the  economy for the rest of us.
    The only way the economies of North America are going to restore is when each of us individuals take responsibility for the part of its destruction that we "the consumer" is causing; and  change our spending habits. Make it a personal priority  to be concerned about where our money is going. We have to stop making; "How cheep it is" as our highest buying priority. Make your first "buying" priorities be  "where the item comes from", "where is your money actually going", (off shore?) or are you "supporting your local community", are you "supporting your fellow Americans"?
    Brake rotors are a good example. There are many brands of brake rotors available in plain  and claimed to be high performance drilled and slotted sold at places with that companies name on it like Summit and so on. These are relatively "Cheep" off shore made rotors (and you get what you pay for) and the same model of  can be had for higher cost, made in America and it is in fact better quality steel with higher carbon and nickel content so it is actually more corrosion resistant and is a metal that absorbs and dissipates heat more evenly and quicker which results in longer usage life before is begins to warp and pulsate.
    I just bought rotors for my 2009 Malibu, they had the standard rotor ( made off shore)  for $23 each. The same cheep off shore rotors came in drilled and/or slotted disguised as "high performance"for more money. I purchased a pair of (made in north America) brake rotors from a lesser popular named company. Yes I had to shop around and ask many questions to find better then the what most store are selling. These are unidirectional finned (left and right sides which have better cooling) made with American metal containing higher ratio of nickel, molybdenum and carbon ( they are also actually .004" thicker new) and are spin  balanced for $65 each.  Its not like i paid more money for the same thing. I not only purchased American made (sporting my fellow American and my local community) I also "got what I paid for" , better brakes and a higher, safer quality of life.
    Think about it, cheap is not the way to go for many reasons.
    M1D
    Post by donivan65 Thu Feb 13, 2014 9:11 am
    The Nova Disk Rotors that move the wheels outward on my van, are tough on bearings,,,,,,
    Post by m1dadio Thu Feb 13, 2014 5:31 pm
    Hey Don;
    I always thought the nova rotor set up on any van would be harder on the outer wheel bearings directly because of the 3/8 off set of the wheel mounting and probably even more so with your increased off set wheels. The further out the wheel goes the more the center of load becomes a lever action against the outer bearing. and the load becomes moved off the inner bearing and that amount put directly onto the outer bearing. The Nova would have had an inset wheel which would have placed the load more centered under the hub and dispersed the load to the bearings with a better distribution of the inner taking about 75% of the weight loading. Thats why I tried so hard to find a rotor that would give zero off set on the van spindle, but absolute zero just couldn't be done unless we want to go to custom hubs which would add a ridicules cost to a disc conversion.
    You have all those disc bracket set ups. have you considered installing one of the other designs?
    M1D
    Post by donivan65 Thu Feb 13, 2014 6:11 pm
    I did have a problem once with an inner cup spinning on my original Nova rotor,,,which ruined the rotor,,,,,,I think the cups came in  the rotor,,,,,,probably from Taiwan,,,,,,everything about my van is wrong for the bearings,,,,,,offset rotor, offset mags,,,,hauling engines and concrete,,,,,and every trip is a 100 miles through the mountains and winding roads,,,,,,,,do you got some titanium bearings and cups?
    Post by m1dadio Thu Feb 13, 2014 6:32 pm
    Sounds like whats really going on is you work your van hard and get every last mile out of your bearings.
    I know you can get bearing with a larger bearing surface and you can also get Chrome/molly bearings and cups. But they are pricey
    I have seen cheaper hubs and rotors that expanded do to heat and let go of the bearing cup while hot, enough to let it spin and of course that only continued to get worse. That happened to a van hub I have.
    M1D
    Post by donivan65 Thu Feb 13, 2014 8:21 pm
    I will wait until something breaks until I change my system,,,,,,,,so,,,, for the guys wondering about what wheels will now fit over your disk brake brackets,  are they all the same dimensions or do you have a bracket/caliper combination that has a little more clearance as to not interfere with certain types of wheels,,,,,
    1968 G10 Chevy Van front wheel bearings  Question...... 71_mca10
    Post by m1dadio Fri Feb 14, 2014 9:59 pm
    Here is all I can give people on this question. The only dimension I can give is the diameter back at the bracket. The caliper has a curved shape getting smaller towards the wheel so the diameter diminishes as you get closer to the wheel flange. The caliper will be closest to the wheel flange when the pads are new. A newly installed disc brake setup will have all kinds of unpredictable and unnecessary metal protrusions on the caliper and sometimes the bracket or pins that can be ground off if just touching your wheels.
    This picture can help explain what I am saying.
    1968 G10 Chevy Van front wheel bearings  Question...... Diamet10
    1968 G10 Chevy Van front wheel bearings  Question...... Image10
    These are the Max diameters at the brackets that all fit into my 15" wheels and this can be reduced some by grinding off a little.
        M1D10KN (Nova rotor)      12.9142"  (about 4.00" back from wheel mounting flange)
        M1D80TA ( Firebird Rotor)  13.4194"  (approx 3.0" back from wheel mount flange)
        M1D2KV   (Corvette rotor)  14.206"  (approx 2.5" back from wheel mount flange)
    Probably the most significant difference to the Nova rotor set up is that the wheel mounting flange is set out about 3/8" more then the other two which would make more room for awkward interior shape of some older wheels.  Most newer wheels are made with much cleaner interior shape giving clearance for any disc brake set up made.
    In the end I remind people converting to disc brakes that wheel fit is the gamble part you just have to deal with when it comes time to install your wheels and there is many things you can do if they don't fit right away at first try, but you might end up having to get different wheels.
    Hope this helps.
    Don; you wheels have such dramatic offset that they would likely fit any disc brake setup
    M1D
      Current date/time is Sat Nov 16, 2024 12:24 am
