I have a Dodge a100 van
vin# A1A2S87207
It has a 90 inch wheel base.
225 slant six 3 speed automatic
has brake shoes all around
Tail lights all say 1964
This should be unexpected from what you may have thought.. work is still in progress, but near completion. I did all of these murals with spray cans and paint markers just for fun. A little more to do before clear coat. Can't show the other side yet becasue the van is against the garage wall. I wanted to do a woodstock theme.G-Man wrote:Great looking dash, now I have to see the rest of the van
like i said the vin tag is for a 68. after 40+ years things get changed around.doors are easy, dash spoiler, dual or single master, but the easiest thing to change takes four rivits, the vin tag itself. as long as you have a title for it all is good. i bet a significant portion of the cars from the barratt-jackson aren't as real, as we are led to believe. see if there is a corresponding number stamped into the frame rail on the right side by the wheel.dix wrote:Ok Jeff you have my attenion what are you seeing ?? altho my 69 van looks a lot different ,
