Glad to be here and to learn more about these cool old vans.
Lets get the important part done first: PICTURES!
The back story...
I found this one listed on Craigslist for $1000. Here is what the ad said:
This used to be the van used for picking up food from St Marry's Food Bank for a Mission run in Downtown Phoenix for the homeless. It was parked in 1980 and never moved since. I literally went to the landfill and unloaded 1300 pounds of beans and rice this past Weds that has been in it since it was parked. Word has come from reliable sources that shortly before it was parked the motor was overhauled w a rebuilt head and rings and bearings. It aint pretty as it is very dirty and it don't smell real good either but for a cool project for someone wanting to build one this is rust free and a good start. Ford 9 with 411's. I put a set of used in good condition tires and wheels on it to be able to move it around that will go with the van. I will not be low balled as I have 0 problems taking this to metal scrap which is exactly what will happen this coming week if someone doesn't want to buy it. 1,000 OBO.
Here is what I have learned since. The part about the engine being rebuilt was unfortunately not the case. It has a layer of grime that appears to be untouched since the van was built. The engine is a 170 and it has the three-on-the-tree manual transmission.
Door tag says:
VIN E16TH667129
90" wheel base
M Wimbledon White
Medium Blue Crush Vinyl and Medium Blue Stitch Pattern Vinyl
E160 SuperVan
Trans A 3 speed manual
Axle 18 4.11 Ratio
LA California DSO
It appears the van was parked for at least brake problems as everything between the drums and the backing plates is missing.
The previous owner told me that squirrels had taken up residence in the van, living well off the rice and beans. By squirrels I am pretty sure he meant rats. The floor of the van had a several inch thick layer of decomposed beans and rat turds. The one thing he got exactly correct is this: "it don't smell real good either." Fortunately most of the really nasty part was done before I got it and a session with the power washer has done wonders. It still stinks a bit though.
The rats ate more than just the rice and beans. They seem to selectively eaten a good deal of the wiring harness, with a focus on things that are vital to getting the van running.
I have ordered a small mountain of parts and when they all arrive I will see if I can't get the heart beating again. My plans are to fix as much as possible while retaining the original patina (not scent) for a little while at least. Knowing how these things usually end up, it will get completely rebuilt before I am done.
