Thnx guys,,, I have been working on and savin pictures of all the subjects for a long time and enjoy being able to share them for people......
Sean and I have been talking, and in all honesty he is battling some serious issues so I do understand. Life has turns we dont expect. and not my place to say.
On the other cheek,,, I have been saying the same about the V8 conversions for so long I have forgotten when I started yapping about them. It really is a LOT of work for the 300 in order to compete, the 300 a VERY torquey motor, some say even more than the 302.
IMO,, and an old statement, there is so much MORE to building a bad boy six than a simple Windsor block. The air cleaner is right in the middle, and the ONLY ADDED expense is to convert the cross member towers over in order to use the V8,,,, no matter what you do, same radiator and fan issues, alternator and transmission cooler upgrades,,,, all exactly the same!!!
The big six with a stock intake and exhaust will always boil the gas in the carb with a big cast iron heat sink bolted up to the bottom of it. Then Ford even realized and issue and put a cold air manifold to blow cold air onto the intake runners with a note on the air pump stating that "it is normal to hear the cooling fan run after you shut the motor off",,,,After all, its not like its under a big F-100 pick ups hood with plenty of room for the heat to dissapate. On top of that,, then we insulate the little heat box we stuff it into!!!! Difficult at best to get cold fresh air for the carb???? no place for the heat to go to???? bigger intake manifold and carb and so that I have to cut out the side of the doghouse,,,,, SO,,,IMO,,,, At least the
V8's air cleaner is right in the middle with no exhaust manifold to boil the carb... as they go out the side and down,,,,,JUST IMO.....Have heard some pretty funny sounding dual exhausts though...LOL Its just my opinion,, but I think for the same amount of moneys,,, the V8 is actually less combersome and an easier power boost. For the purist who likes the idea of building a hot rod 6, in its own right that is pretty neet!!!! The best I have seen yet was an old Ford hubcap for an air cleaner,,, but again,, it had a hood about 4ft long to stuff it under instead of puttin it in a barbecue box.
Vic,,,
