While I have everything out of my van, I am going through it to get rid of every possible rattle. I found that the drivers side wall rattles a lot, and it looks like the ?caulk? that is between the upright supports and the sheet metal has failed, causing the panel to slap the uprights while the van is moving. I am thinking I will just pry the gap open a little and squees in some PL construction adhesive...
Anybody else have this issue?
How did you fix it?
Is PL the right thing to use?
Thanks,
Dawg
How did you fix it?
Thanks,
Dawg
