I need to replace the rubber gasoline filler hose, on my 1967 A100 Sportsman. Has anyone found a replacement radiator hose that works just as well as the original replacement hose? hose?
Rubber gasoline filler hose...
Re: Rubber gasoline filler hose...
gates 24716 is the hose
dont use a radiator hose its not made for gas, use this one its for gasoline
- Number of posts : 8769
west coast it will be to long . just cut to size needed
Where do you purchase, the Gates 24716 hose?
Any auto parts store should be able to order it for ya, especially since you have the part number now.
Thanks
slowflapper- Number of posts : 957
yep, comes up under orielly auto parts, that's the same hose I got (and I bought it from them).
I just ordered mine! thx for the part number dodge man. We should sticky info like this! Does anyone know the hoses required for the overflow/vent hoses as well on the filler neck?
Picked up a fuel filler hose at NAPA #1038, a bit pricey at $34 with tax but it beats the soggy dripping radiator type hose that was on the van. Attached a few pictures of what happens to a non fuel hose exposed to today's gasoline. All those little flakes of rubber is what is left of the inner tube lining of the hose, these are now in the bottom of the tank and more than likely the fuel filter.
thats why you never use rad. hose for fuel line hose
^^^ Youre right, but it takes a long time to get that way. I dont have a "real" gas tank right now, so Ive been using my temp tank (boat tank) and the filler is a piece of rad hose. Been on there for several years now, used when building several cars.
It'll work for a "now" fix but its still not a good idea. Definitely get you out of a jam tho.
