    Rear corner panel replacement ?
    Cdcracing
    Cdcracing
    Number of posts : 245
    Rear corner panel replacement ?  Empty Rear corner panel replacement ?
    Post by Cdcracing Wed Feb 27, 2013 10:40 am
    What is the best way to replace the rear corner panels on 63 econoline ? I finally got me a van and the corner pannels have dents in them . I know how to weld I do it for a living so that's not s problem . Do you just hold the new one up there and mark the old one and cut it ? I new at restoring so any advise is great . Thanks
    Number of posts : 3046
    Rear corner panel replacement ?  Empty Re: Rear corner panel replacement ?
    Post by RodStRace Wed Feb 27, 2013 11:46 am
    Yeah, you want to place the cut so the panel is perfectly aligned, and I'd suggest a cut inside the lines so you can file or sand the opening for a perfect fit (assuming butt welding).
    Normally, this is done with a MIG and you want a consistent gap. You can use magnets or panel clamps to keep the panel located for the first few tacks.
    Normally, you just tack every inch or so, allow to cool and tack again, splitting the distance. Repeat until it's fully welded, do not run a solid bead, it causes too much warping!
    Clamps
    http://www.amazon.com/Northern-Industrial-Welders-Panel-Clamps/dp/B0028YIRYW
    Cdcracing
    Cdcracing
    Post by Cdcracing Wed Feb 27, 2013 1:03 pm
    Thanks that's great advice !
    Post by RodStRace Wed Feb 27, 2013 7:47 pm
    One of many tutorials on the process.
    https://www.youtube.com/watch?v=i4q1TExpmfY
    Number of posts : 864
    Post by Casimier Sat Mar 02, 2013 8:03 am
    Thanks for that Rod
    Cdcracing
    Cdcracing
    Post by Cdcracing Sat Mar 02, 2013 8:39 am
    RodStRace wrote:One of many tutorials on the process.
    thank for the info .
      Current date/time is Sun Nov 17, 2024 10:46 am
