Got some Questions on Dog House Conversions .....
Vanish- Admin
- Number of posts : 5155
I was Wondering about the second Gen Dog House conversion !!! When this is Being Done ..Do You use a second gen engine cross member as well ???? or do you stay with the first gen engine cross member ???? also ... after the second gen dog house has been installed . has any one also used the second gen 4 Row Radiator as well ???? all the vans I can remember with the second gen Dog house have had a different Radiator set up in them !!!! is there a Reason for this ???? Thanks' for any help you can give me on this !!!!!!
,,,Vanish,,,
MCMLXV
I used the second gen dh
kept the first gen crossmember.
the reason for using the 4 row crossflow
radiator is because, usually the second gen
dh has the upper rad mount already made on it.
and all you have to do to make that rad work is
the lower rad crossmember, and you are in like flynn.
although some of the 2nd gen dh are from 6 cyl vans
and do not use the cross flow rad and have to come up
with something else.
Vanish- Admin
panelmanrd wrote:I used the second gen dh
So Did you use the 4 row Crossflow stock second gen Rad in your conversion ???? Most the vans I have looked at use a Down flow first gen style Radiator !!! I geuss what I am asking ... after you get the dog house in the van .. is there Room for the stock second gen Radiator set up ???? sure seems like that would be the way to go ... But almost all if not all the vans I have seen havent had the second gen Cross flow in them ??????
,,,Vanish,,,
MCMLXV
m1dadio- Chevy Guru
- Number of posts : 1778
I used a 2nd gen dog house which was from a V8 van. I also used the 2nd gen 4 core cross flow.
Even though the dog house has an upper rad mount I changed that to my own upper rad mount that was closed in to control air flow and Like another vanner since my instalation I used the 2nd gen lower rad cross member but also I reversed it to move the rad forward at the bottom and moved the rad mounting cups over for rad fit tightest to the passanger side.
I used the 1st gen engine cross member.
click on the picture for full view
M1D
M1D
There are two different 2nd gen radiator set-ups. The downflow, and then the crossflow. The crossflow was used for v8's or for sixes where additional cooling was required (optional). The radiator mounts are completely different between the crossflow and downflow radiator doghouses.
I did mine almost identical to m1d`s
second gen dh first gen crossmember with
a 350 fits nice.
a 350 fits nice.
Bear- Number of posts : 849
someone once said useing a 2nd gen motor cradle in a 1th gen van drops the motor lower true or not i don,t know i have a extra one was going to use it in my no-door with a v8 dog house
Vanish- Admin
With the exception of Just a Couple ... all the second Gen dog House Conversions .. almost always use the first gen Rad and I was wondering why ??? Sure seems like a lot of work Not to take advantage of that Bigger Radiator ... I was thinking there Must Be a Problem there ?????
,,,Vanish,,,
MCMLXV
i agree big is allways better
Here's the 2 side by side. 1st on the left. The height looks the same to me. What I did notice was it looks like the 2nd gen might move the engine forward if used in a 1st?? I've never been around a 2nd gen enough to know how they are set up.
I'm pretty sure I have them facing in the same direction by the offset.
yea like i said it was talked about i think over at vcvc long time ago but intersting there is a differnce in the two thanks digz that may come handy in fabing with motor more forward.
There isn't a quick and easy way to hang the 2nd gen rad saddle on a 1st gen that I could see, I've looked into it myself. Gman had a bracket made that incorporated the 1st and 2nd gen mounts to hold up an aftermarket X flow but probably would have worked on a stock X.Vanish wrote:With the exception of Just a Couple ... all the second Gen dog House Conversions .. almost always use the first gen Rad and I was wondering why ??? Sure seems like a lot of work Not to take advantage of that Bigger Radiator ... I was thinking there Must Be a Problem there ?????
Vanish- Admin
Well I am going to Put a second gen Chevy Dog House in a Econoline .... and also going to have a tunnel .... But back to the Chevys !!! a second gen dog House ... in a first gen ... Just Don't seem Like it would be that Good of an Upgrade .. with out that Big 4 Row Cross flow Radiator to go with it !!!!! seems to me if your going to keep the down flow ( smaller Radiator )... you would be better off with a Tunnel and those Tin Boxes on both sides ??? Thoughts ????
,,,Vanish,,,
MCMLXV
Other than giving the engine a little more room and the air a little better chance to escape I'd have to agree with you. Just a note , my crossflow rad is the same sq inches as the 1st gen rad was and a 2 core aluminum.
Hey Don , are the 2nd gen 6 banger rads wider than the 1st gens then?
Thanks Don. One more question. How does the 2nd gen Xflow core compare in sq inches to the 2nd gen 6 banger?
Thanks again, Looking at the pics of the two, I wouldn't have thought that much difference in surface area. But 73 sq is alot , especially tossing in more cores.
I was looking at the two crossmembers and
the difference has to be is where they are bolted in the
frame because the trannys are the same length
and the drive shafts are the same length on the 90 inchers
whether it is the first or the second gen.
That sure would make sense. One thing I think I have learned from the forums and what I have tried,,Is there is very little between a 1st and 2nd that is a bolt in swap. Other than most of the same skin,, 2 different animals.panelmanrd wrote:I was looking at the two crossmembers and
it is amazing just how much won`t swap from
1st to 2nd. springs, axles, engine crossmember,
the drag link is different, steering arm on left
spindle, sway bar, the spindles will swap.
I do know that a 2nd outer steering column will
fit the 1st stering box, lets you use the 2nd gen
turn signal switch along with any 67 and up gm
steering wheel, and you also get 4 way flashers to.
