by dodge man Thu Nov 29, 2012 10:05 am
i can always change the caster angle by loosening the u bolts and turning the axle that way when i'm done lowering the rear i can recheck the front end and make adjustments as needed, when done i'll weld the purches to the axle, i have more work to do on the front first, i need to pull the lower part of the radiator toward the front of the van, i need more clearance so the lower rad. hose does not hit the axle, i'll most likely cut off the bump stops,
