    tires on a 1962 econoline, stock appearing
    12speedfurd
    12speedfurd
    Number of posts : 35
    Registration date : 2012-08-23
    tires on a 1962 econoline, stock appearing Empty tires on a 1962 econoline, stock appearing
    Post by 12speedfurd Fri Sep 07, 2012 1:46 pm
    Hi guys, i searched around a bit but didn't find this question addressed. What is the original tire size that came on a 1962 econoline pickup? Right now my pickup has f78-14s on it.
    scarlin
    scarlin
    Number of posts : 258
    tires on a 1962 econoline, stock appearing Empty Re: tires on a 1962 econoline, stock appearing
    Post by scarlin Fri Sep 07, 2012 5:22 pm
    Can't speak for a 62, I have a 67 owners manual. F78's were late 60's to 70 tire sizes. In 67 the sizes were 6.95 x 14, 7.00 x 14 or 7.35 x 14. I have an original spare in the 66 Falcon, it will not hold air.
    Some of the very early's had 13" rims.
    12speedfurd
    12speedfurd
    Post by 12speedfurd Fri Sep 07, 2012 8:09 pm
    After some investigating I figured out that the hubcaps on my pickup are from a 57 ford car. They look pretty good imo. I did read in a few places that the early econos had 13" wheels. I will probably just stick with a 14" wheel.
    Vanner63
    Vanner63
    Number of posts : 235
    Post by Vanner63 Sat Sep 08, 2012 5:37 am
    For 1961 and 1962 the wheel/tire size was 13". Starting in 1963 Ford offered the 14" option and also the Heavy Duty option. But you didn't have to get the Heavy Duty option to get the 14" wheels/tires. There is the possibility that the 14" wheel/tire size became available on late 1962 models, as Ford generally does running model changes.
    Number of posts : 2016
    Post by Barnabas Sat Sep 08, 2012 8:02 pm
    The 1957-1963 Ford Truck Parts and Accessories Catalog lumped all of the 1961-1963 Econos together as far as wheels and tires go. Here is what they list as the options.
    tire size = rim size
    6.50 x 13 = 13 x 4.5
    6.50 x 13 = 13 x 5.5
    6.95 x 14 = 14 x 5.5
    7.00 x 13 = 13 x 5.5
    7.00 x 14 = 14 x 5.5
    7.35 x 14 = 14 x 5.5
    7.50 x 13 = 13 x 4.5
    7.50 x 14 = 14 x 5.0
    8.00 x 14 = 14 x 5.5
    When you get down to the hub cap section, besides the 13" for all three years, they list a 13-3/4" hubcap and a 10-1/4" hubcap, both for the 14" rim for 1961-1962, both with 1961 part numbers. Thus according to the hubcap chart, they might have offered the 1961 and 1962 Econoline with 14" rims.
    FYI - My 1964 Heavy Duty Econoline cargo van came stock with a set of 13" rims.
    12speedfurd
    12speedfurd
    Post by 12speedfurd Sun Sep 09, 2012 1:53 pm
    Thanks, that is very helpful!
    Barnabas wrote:The 1957-1963 Ford Truck Parts and Accessories Catalog lumped all of the 1961-1963 Econos together as far as wheels and tires go. Here is what they list as the options.
    Number of posts : 3046
    Post by RodStRace Mon Sep 10, 2012 7:30 am
    If you are really wanting OE looks, don't forget to get bias ply tires, not radials.
    They have a completely different side and tread profile.
    They are also specialty tires (expensive) and handle pretty poorly in comparison to modern tires.
    http://www.cokertire.com/650-13-u-s-royal-1-whitewall-tire.html
    tires on a 1962 econoline, stock appearing Us-royal-narrow-whitewall-large_4
    12speedfurd
    12speedfurd
    Post by 12speedfurd Mon Sep 10, 2012 1:07 pm
    Yep I have considered bias tires from coker, but I want it to handle and drive well. I am going to go with radials that look old. You can tell they are still radials, but they don't have all the big lettering on the side. Its a good compromise imo.
    RodStRace wrote:If you are really wanting OE looks, don't forget to get bias ply tires, not radials.
      Current date/time is Mon Nov 18, 2024 1:26 am
