+49
66mnecotruck
back2thewoods
jfox
Dawgboy
NipRing
SteelyVan
SDEconoTruck
rustybug13
Vantastic
kaz
Leftcoast65
kookykrispy
sandyvan
64chevy
53 posters
The Surfing Guy's 65
- Post n°1026
Re: The Surfing Guy's 65
Hey Scott! Every few weeks drive the van instead of your main wheels, even if it's just to the store. It's fun and good for the van. And, as Don will surely tell you, we gotta get these vans out so people can see them!
the_surfing_guy- Number of posts : 409
Registration date : 2012-08-15
- Post n°1027
Thanks for coming down the hill Don and getting her running, BUT the reason I stopped driving her in the first place was mainly due to the horrible noise permeating from the goulash of gears I call my differential. It's probably gonna be a while before I tackle this feat, but at least she's safe and warm tucked in my garage. For now, it's...
- Post n°1028
Looks like Scotty's got his hands full!!
- Post n°1029
So Scott, while you are taking out the diapers, get a pan, unscrew the top 2 bolts on the differential cover 1/2 way,,,,,,,then remove the other 8, and let the cover hang there till all the oil drips into the pan,,,,,let it drip for a couple of days,,,,,then see if there are pieces of metal in the oil with a magnet,,,,,I think your pinion shaft bearings went bad,,,,,,,
- Post n°1030
- Post n°1031
Scottie, you really follow Doni's instructions to a tee, including taking out the diapers!!! Go PATS!
- Post n°1032
,,,,,,,you are going to be in BIG trouble using up those Pampers to wipe up the oil spills,,,,,,
- Post n°1033
Your original rear end had the broken pinion shaft bolt and the side gears were spun on the carrier assembly,,,,,we used parts off the Orange van rear end that me and Rich took apart,,,,,,,I would say you will be probably taking that rear end out and taking it to San Diego Gear and Axle to be rebuilt,,,,,,do you have that old rear end in your back yard?
- Post n°1034
- Post n°1035
Welcome back Scott! Nice to see you and Don back at it. There's a lot of us who would love to learn from the Govna! Hope the family is doing well.
- Post n°1036
Hey guys, welcome back! Scott, careful, you're getting as bad as me, ignoring our precious vans!
So is that another rear end you picked up, not the Orange van rear end?
- Post n°1037
That Orange Van rear end me and you took out a while back, had that 427 in it and the pinion splines were twisted so I did not use the pinion out of it last time we had Scotts rear end apart,,,,,his side carrier bearings spun so I used only the carrier housing....but his pinion bearing gave up such that when he took off, the pinion shaft would slide back and hit the ring gear housing and it made some big noise,,,it was really hard to get that shaft out,,,,the bearing was frozen onto the pinion shaft and would not easily come out of the housing,,,,but he needs to get new bearings, a seal and a crush sleeve and we can get him back on the road again,,,,,,,but it was just one more repair that the van needed,,,,,,come to think of it, that makes just about every single piece on that van that needed to be fixed or repaired since he got it,,,,,,,,
- Post n°1038
- Post n°1039
Nice to see you helped Scotty get back on the road again!!!
- Post n°1040
Thanks Dr Donivan! Good to be back in the saddle! Vanny, our Sox are awful AGAIN this year!!!!
- Post n°1041
Alright Scott (and Don)! That will be nice to have done. I'll be doing that sometime on mine. I can feel it howling a bit on the freeway.
- Post n°1042
Scotty, I agree, sox are not looking so hot this season. Some need an attitude adjustment!!! Vanagain, these vans are like us, the older they get, the more trouble they have with their rear ends. Hee hee hee!!!
- Post n°1043
- Post n°1044
It's been a while since I've checked in with the V-V crew, so here is the latest.
I've been cruizin' the van whenever I can and she is running like a top! I believe mechanically, she is just about complete with the exception of some minor tweaking. Maybe a carb rebuild, as this is the original carb and it seems to start and idle a little rough...nothing major though...
I did have loads of fun in it being out on the 4th!
- Post n°1045
I'm sure the Van is happy to be back on the road again too!!! Congrats and welcome back Scott!
- Post n°1046
Mounting the safe
Since, I really do use my van for trips to the beach, especially for surfing, I needed to come up with a way to leave my valuables for hours at a time in a van that does not really lock up. I don't know where you all live, but here in San Diego, the beach towns are chock full of dirty scoundrels who would just LOVE to take your wallet, keys, smart phone, etc. and pawn it off for a six pack.
In the past, I would "cleverly" stash all my valuables around the van, but I was always merely rollllllllling the dice! I decided to mount this small safe behind the driver's seat, so I could lock my goodies tight and go have some fun! Now, all I have to do is lock 'er up, clip the key on my lanyard, place it around my neck and secure it under my wetsuit.
Here's what I did. I drilled out the 4 mounting holes in the bottom of the safe, lined it up with the upper ridges of the bed and mounted the safe using long self-tapping screws with washers. Then, took some of that nice rubbery insulation that I used for "sound-proofing" the van walls and made a comfortable bed for my possessions.
Here's what it looks like. If all the stars align, I will take if for a test run later today!
- Post n°1047
- Post n°1048
The baby must be taking longer naps for you to get out of the house now,,,,,,,,,,,,
- Post n°1049
Looks like Scott has fully embraced the West Coast laid back surfer dude lifestyle!!!
- Post n°1050
