+49
66mnecotruck
back2thewoods
jfox
Dawgboy
NipRing
SteelyVan
SDEconoTruck
rustybug13
Vantastic
kaz
Leftcoast65
kookykrispy
sandyvan
64chevy
53 posters
The Surfing Guy's 65
Vanish- Admin
- Number of posts : 5155
- Post n°526
Re: The Surfing Guy's 65
Scott how did they fit the pedals ??? I got some from brothers and they dident fit well and a year later they were all cracked up !!!!!!
,,,Vanish,,,
MCMLXV
the_surfing_guy- Number of posts : 409
Registration date : 2012-08-15
- Post n°527
They are made for 61-65 Corvairs, but fit our pedals like a glove...no excessive force needed. There is an opening on the bottom side that allow them to slide on from one direction and then you fold the lip over the other side of the pedal.
- Number of posts : 12224
- Post n°528
- Post n°529
- Post n°530
NICE !
- Post n°531
Sweet!
- Post n°532
Went down to Scotts place today,,,,,put all these wires back where they belong,,,,,,told Scott,,,,plug the bulbs and connectors back in to the dash that you marked before you took them out,,,,,,,put the dash back in,,,,,,turned the key and the dash goes up in smoke,,,,,,so,,,,,,,,did I rewire it wrong,,,,,,or did someone else cause the fire,,,,,,,,,,,,
- Post n°533
sandyvan- Number of posts : 526
- Post n°534
NO!! You're joking I hope???
- Post n°535
Poof!! Sad!! Lets check all those power wores & grounds?? been there done that too!!
- Post n°536
I ain't joking,,,,,Scott said too bad I didn't get a picture of it,,,,,,I was kind of busy putting the fire out,,,,,,,I was not going to do a take 2,,,,,,,I fixed it,,,,,but you guys can try and figure out what happened if you want until Scott confesses,,,,,,,even a Pope couldnt help him now,,,,but power and ground sure is part of the answer,,,,,,
- Post n°537
Wow, that sucks! Make sure all the gauges that get 12v are on the right
Post. Glad tou fixed it!
- Number of posts : 14776
- Post n°538
Poor Scott,
I'd have probably done the same thing! Real subtle there Don! There's that learning curve again. Like you said Don, he's gonna know his truck inside out by the time he's done. At least he's got some nice shiny mirrors to add and you saved the rest of the van from going up in flames. Give yourself a pat-on-the-back!
- Post n°539
I tell you how it is,,,,,,and I put this stuff up to entertain you,,,,and show how things are done,,,,,and in this case,,,,,the fuel gauge and wiper switch use the same type connectors,,,,,and the the fuel gauge is a positive while the wiper switch is a negative circuit,,,,so Scott plugged the positive circuit into the negative wiper switch which,,,,in our vans, is an unfused circuit,,,,the ignition circuit,,,,so it cooked the feed wire in the fuel gauge wiring loom,,,,,so 1st thing I do is say Scott, look at the color schematic that VanAgain gave you and tell me what colors are SUPPOSED go to the fuel gauge,,,they should be Tan and Pink,,,,,so I reach up and unplug the fuel gauge and the wires aint Tan and Pink,,,,,,the fuel gauge did not mind having the wrong wires on it, but that wiper switch, which was stuck on,,,,,really HATED having those fuel gauge wires on it,,,,,but its all fixed,,,,,,he can finish wrapping up the wires and putting the seats in it and lets go out and meet the World......
- Post n°540
So, what you're saying is, read the diagram before making the connections and then double check it once you've made the connection to be sure you got it right. Sometimes when you've got a spaghetti western going on like in that photo Scott posted, it can get a bit confusing as to which direction the wires are going. I not only find your posts entertaining but all kidding aside, I'm learning a lot as I watch your progress on this van and the many others you assist with. I joke around but want you to know that I really appreciate the efforts you make to teach as you progress. Oh, the other lesson is always have a fire extinguisher close by for just this type of emergency!
- Post n°541
Well, just so this thing does not get too blown out of proportion...there were no flames...just smoke !!!
And as a mentor, a Governor and a friend, Don should have told me to be careful and not get the wires crossed . How was I to know that when he said plug in all the connectors, that just because I found a "fit", didn't mean that it was the right fit! Lesson learned and I guess I need to ask the right questions.
Anyways, got all the wiring tightened up in looming...
AND more exciting than that, I got to put the doghouse lid back on! Man, it's been many a moon since that thing has been on!
- Post n°542
Scott should get an award for showing you how easy it is to burn up your van,,,,,theres 2 connectors, right next to each other,,,,they look the same,,,,but put them on the wrong terminals,,,and the van catches on fire,,,,,EASY to do,,,,,you just can't think of everything,,,,,but I bet you remember this post when you pull the dash out of your vehicle,,,,,and that the point of all this drama,,,,this is good information,,,,,,you won't find that in your shop manuals,,,,,so cheer up Scott,,,,,you probably kept someone from messing up their van,,,,,,,
- Post n°543
Lesson learned and we have all done it. Trust me, that smoke is impossible to get back into the wire.
- Post n°544
Scott, don't forget to save a handy spot for a fire extinguisher just for good measure!
- Post n°545
Don't tell anybody,,,,,but for all the stuff I know,,,,,I had to mess it up 2 or 3 times until I got it right,,,,,that's kind of how I learn......I ain't very smart.........
Big W- Number of posts : 3282
- Post n°546
- Post n°547
Like we did on this van, one wire at a time,,,,,we sent power from the battery to the fuse box,,,,,then to the ignition switch,,,,then another color from the ignition switch to the fuse box for the accessories and back to the coil,,,,,then another color from the ignition switch to the starter....thats the main circuits,,,,,cut off the old wires and what you got left is the accessories,,,,,and they just go from the fuse box, to a switch and then to the equipment,,,,,and put a REAL fuse box in that Ford!!!!
- Post n°548
Good idea about the fuse box. Definitely putting in a nice one with relays as well for the electric fan. Did you guys put a new fuse box in scotty's van or use what was already there? And if so do you have any pics as to where it is put in the van for ease of accessibility?
- Post n°549
The old box is still there,,,,,there aint many fuses in it,,,,,I just replaced the 3 main circuits for now,,,,power in,,ignition out and starter out,,,,(that ignition out is the hardest,,,,,it splits off to feed like 8 different circuits before it gets to the ignition coil),,,,,and used a heavier gauge for them,,,,,those old glass fuse clips and terminals are not very good,,,,I am liking these universal spade fuse boxes,,,,you need 2 fuse boxes in a vehicle,,,,one where the fuses are hot all the time,,,,the other that only get hot when you turn the key on,,,,and with these, you hook battery to one, a wire from the ignition switch to the other,,,,then run the feed wire from one fuse terminal to each switch or piece of equipment you want to protect,,,,,and put them where you want,,,some people put them in a box behind the drivers seat,,,,it don't matter,,,,you really don't ever have to mess with it once you got all your systems working right,,,,it does not have to be easy to get to,,,,,
- Post n°550
