    flywheel ring gear
    Number of posts : 648
    flywheel ring gear Empty flywheel ring gear
    Post by Rayallen Fri May 18, 2012 12:55 pm
    I counted my ring gear and found that it has 132 teeth.
    Ive checked both Rockauto and Mac's and neither have a ring gear with 132 for a Econoline, mustang or a falcon. any of you guys change the number of teeth. pros and cons to this. Summitracing does have a 132 ring gear but im not sure if it will fit my flywheel.
    Ray
    flywheel ring gear Empty Re: flywheel ring gear
    Post by Rayallen Fri May 18, 2012 1:21 pm
    found the damn gear at advanced auto parts. I thought for sure Macs or Rockauto would have had one.
    Post by Rayallen Fri May 18, 2012 6:51 pm
    Scratch that. I just went to advance, autozone and oreillys. Each of them out of stock and show the supplier not having any the warehouse so they could not order one for me. The hunt is still on...
    Number of posts : 575
    Post by austinmodhouse Fri May 18, 2012 7:00 pm
    try a transmission shop? if they don’t have one, they should be able to tell you where to go/what to do.
      Current date/time is Thu Sep 19, 2024 1:29 am
