    Ring gear is bad
    cali2chitown
    cali2chitown
    Number of posts : 188
    Ring gear is bad Empty Ring gear is bad
    Post by cali2chitown Mon Jun 22, 2015 4:11 pm
    I took my flywheel in to be resurfaced today and they told me the ring gear was bad which I never even noticed. After counting the teeth on the ring we found it had 168 teeth but there are really non available aftermarket. I've heard you can put a 164 tooth ring gear on them but I really don't know. Has anyone ever heard of this? I have a 66 epup that had a 240 6cyl but i'm going with a 302 now.
    Thanks
    Number of posts : 12245
    Ring gear is bad Empty Re: Ring gear is bad
    Post by donivan65 Mon Jun 22, 2015 5:08 pm
    sometimes you can heat that ring gear up and flip it over if the teeth are still good on the backside,,,,,,
    cali2chitown
    cali2chitown
    Post by cali2chitown Mon Jun 22, 2015 8:55 pm
    I'm wondering if I can even use this flywheel at all. While looking up part numbers for ring gears I found a few post on forums that I will need a 28oz imbalance flywheel if i'm switching to a v8. Does anyone have any idea about this?
    Number of posts : 2087
    Post by Seth G Mon Jun 22, 2015 10:22 pm
    Yeah you will need an imbalanced flywheel. I think the weight depends on the year of the motor. Some need 50oz.
    cali2chitown
    cali2chitown
    Post by cali2chitown Mon Jun 22, 2015 10:28 pm
    I'm pretty sure the motor is from the mid eighties. I just read where they have 28 and 50 ounce imbalances.....but how do I know exactly which one to use...by the year?
    RF Man
    RF Man
    Number of posts : 120
    Post by RF Man Tue Jun 23, 2015 3:43 am
    Be sure to run the numbers on your engine. Ford went to 50oz imbalance in the early 80's(81/82). You cannot mix and match. Not positive,but I think the c4 and AOD might take different size ring gear. I ran into this when I put a C4 in an early bronco with 50oz roller 302. Tom's bronco can help you get this straightened out if you run into this.
    Mike
    cali2chitown
    cali2chitown
    Post by cali2chitown Tue Jun 23, 2015 8:24 am
    Thx Mike.....I'm running the old 3spd that came with the truck. I stumbled onto toms bronco last night and found the same thing. Doesn't the flywheel match the imbalance of the harmonic balancer and i'm pretty sure it's a mid to late 80's block but i'll check.
    tody
    tody
    Number of posts : 91
    Registration date : 2010-09-15
    Post by tody Tue Jun 23, 2015 11:55 am
    flywheel imbalance needs to match both crank and balancer. mid 80s is a good sign that it might be a 50oz engine.
    when selecting a flywheel, you need to keep in mind which bell you will be using. flywheel size needs to match bellhousing size, which in turn determines which starter to use. essentially, there are only two sizes for a 302: 164 or 157.
    cali2chitown
    cali2chitown
    Post by cali2chitown Tue Jun 23, 2015 11:58 am
    Its a 50oz balancer so I just ordered a 50oz flywheel with 164 toothh ring from summit. My ring gear on the old fw was 168 tooth but 164 will work. Thanks!
    Bob
      Current date/time is Sun Nov 17, 2024 1:50 pm
