    Dodge flywheel
    thecruger
    thecruger
    Number of posts : 205
    Registration date : 2008-11-27
    Dodge flywheel Empty Dodge flywheel
    Post by thecruger Thu Apr 30, 2009 4:46 am
    just wanted to know , is the 318 and 360 flywheel the same other than one is balanced and one is not.. Suspect
    are they the same diameter, and have the same tooth count.. and will the 360 flywheel work ok with the original 3spd bell housing Question
    Dodge flywheel Empty Re: Dodge flywheel
    Post by Guest Thu Apr 30, 2009 11:01 am
    I believe everything will work as long as you use the 360 flywheel as you stated The only thing I dont know about it that some motors had the stud for the clutch Z bar and some bell housings had it So that MIGHT cause a problem What are you trying to do?
    thecruger
    thecruger
    Post by thecruger Thu Apr 30, 2009 7:29 pm
    someone put a 360 in my van at some point in its life and they used the 318 flywheel from the original motor..
    so i have a bit of a vibration that never goes away..
    so i need to put a balanced 360 flywheel on because someone did not realized one is balanced and one is not.. Suspect
    Number of posts : 1148
    Post by jkr Fri May 01, 2009 3:51 am
    old part # for flywheel is : 3515497 sometimes this number is cast right into the part. mopar performance part # p4529110. this part is readily avalible and not out of line in price either. also saves from sending a used one out to be resurfaced that it will no doubt need.
    this is for 360 engines.
    thecruger
    thecruger
    Post by thecruger Thu May 14, 2009 4:25 pm
    Well i drove to PA today and picked up my 79 318 with 44k on it..
    the guy even gave me a set of headers that have never been used
    and a four barrel intake for free..
    he's trying to clean out stuff he don't need.. he mainly deals with big block mopar's .. so i was more than happy to take them off has hands...
    Post by Guest Thu May 14, 2009 5:48 pm
    I had a problem with the flywheel center pilot hole being a different size, so I had to have it machined bigger.
      Current date/time is Thu Sep 19, 2024 1:35 am
