So, lubed my window winding mechanism, now my window keeps opening 3-4" when I hit small bumps, and won't stay rolled down either, creeps up 1-2" when completely rolled down. Is there any way to tighten this mechanism up?
+6
Vanadian
eldo
10 posters
Window "bounces" down over bumps...
eldo- Number of posts : 18
Registration date : 2011-09-20
- Number of posts : 12245
I thought that was normal for Chevys?....
Vanadian- Number of posts : 187
Registration date : 2010-11-17
Poormans FiX: I always found that you can pull the handle off change the the handle position so that gravity & natural force help keep them from vibrating down as easy. Sux sometimes though because the position in the earlies is right at knee level.
m1dadio- Chevy Guru
- Number of posts : 1778
buy a new set of "fuzzies" , that will hold the window in place.
m1D
m1D
Sounds like a good excuse to do the power window mod...
,,,,a bungee cord on the handle is guaranteed to work,,,,,
Scott- Number of posts : 1651
The spring is probably just weak with age, mine used drop four or five inches at a time. The guy I bought my van from had an aluminum clip from one of the inside door screws that clipped under the window handle. I eventually bought a Window Regulator from someone parting out a van.
I was told once that someone on www.VCVC.org rebuilds them, but I don't have a name for you.
Power windows is the way to go.
m1dadio- Chevy Guru
Re: Window "bounces" down over bumps...
You should see mine go when I do bunny hops trying to get the front wheels off the ground. Don't get you hand in there or it will chop your fingers off.
And speed bumps! there just comical; if I hit the right speed they go one way then return to where they were.
M1D
M1D
VANagain- Number of posts : 1048
HandiVanMan, sounds like you've Done the conversion to power windows. What mechanism did you use? Out of what car? I'm in the middle of adapting a set from a Plymouth Voyager, but I'm not sold on it.
Thanks,
Rich
Thanks,
Rich
Scott wrote:The spring is probably just weak with age, mine used drop four or five inches at a time. The guy I bought my van from had an aluminum clip from one of the inside door screws that clipped under the window handle. I eventually bought a Window Regulator from someone parting out a van.
Macsdoghhouse
