The side hinges are 2 1/2" wide, while the fronts are 2 1/4",,,,,,,so you got to stretch or stuff 1/4" of gasket somewhere,,,,and that probably won't be pretty,,,,,,next time at the wrecking yard, check the newer Ford and Dodge van REAR doors,,,,if they have gaskets on them, take a razor knife and slice off the outside so you can glue them on your hinge,,,,,,you just might save yourself $9.95 plus shipping and handling,,,,,and it's really hard to pop those gaskets in the body and then try and stick a hinge through them,,,,,,glue ons are way easier,,,,,,,so cut that one in half and make yourself 2 glue ons out of it,,,,,,
Clark's Corvair Parts
- Number of posts : 12248
Re: Clark's Corvair Parts
NipRing- Number of posts : 336
Registration date : 2011-08-14
These were listed for side doors. But as I walk around my van, I don't see wh it wouldn't work on any door. Looks close enough to me.
$240 for hinge gaskets? and since the fronts and sides are different , which one did you get or is it a Corvair only?
So I ordered replacement door handle gaskets for my van this week and they came today. Shipping was 2-3 days, fast. Also I ordered a door hinge grommet because I wasn't sure if it was 9.95 for one grommet or one doors worth (pair). It was one, so Brothers is a cheaper option (4 for $30).
» Cargo Door rubber bump stops.
» Parts,parts,& more parts=dodge, econo & chev stuff
» Sheet metal parts This buisness sells many different metal replacement parts for older cars trucks!! I know i have seen some van parts for our vans here from him!1 If it isnt listed - email or call them!!
» newbie, parts and parts pics and part locations
» Brake light switch
