The little square bump stop that mount with two screw/bolts at the top and bottom of each cargo door. Has anyone found replacements for these. I have a couple that are worn bad and or missing.
VanGo66
Cargo Door rubber bump stops.
VanGo66- Number of posts : 65
Registration date : 2010-09-08
Space Truckin- Number of posts : 1279
bump stops
LMC Truck or Truck Shop Orange CA, , Brothers Truck ?
m1dadio- Chevy Guru
- Number of posts : 1778
Re: Cargo Door rubber bump stops.
I think they are the same as used on the corvan
ck Clarks corvair
M1d
ck Clarks corvair
M1d
Thanks M1, found them on Clarks online catalog page 230...
http://www.corvair.com/user-cgi/catalog.cgi?function=fetch&find_page=230
Of course they are out of stock...
ditdater- Number of posts : 590
CLARKS
DID CLARK SAY IF YOU COULD STILL ORDER THEM ,IF THEY WERE GOING TO GE ANY MORE SOON .>?
DID ANY ONE CHECK BROTHERS
I haven't contacted Clarks, Just going off their website
Eric64- Number of posts : 18
Registration date : 2009-03-24
I checked with them over a year ago and they were out of stock even then, I don't know if they buy up old stock and just haven't found any or the have them reproduced,I just wanted to pass that along so you aren't holding your breath.
I managed to get enough good ones off the junkers I've pulled parts from. Usually the upper rubbers are in good shape and their screws aren't so rusty you can't remove them. I don't think it matters much that the rubber might be real hard with age.
Regarding their shims, it seems to me that every one of these has had one shim. I suppose you could fine-tune the door alignment a bit with them. I actually found one to be too thick to use on the bottom of one door and ended up sanding the rubber down some!
