Hi,
Can someone tell me what type of rear end our econolines originally came with? Are they 7.25" or 7.5"? I've read both in different locations. I have a rear pinion seal that is leaking. What is the best place to buy replacement parts for these rear ends???
Has anyone replaced their pinion seal? Is it just a matter of removing the drive shaft yoke (marking location of retaining nut) and swapping seal? I also read somewhere that we need to go in through the back, remove differential cover and pull out the gears to replace pinion seal....YIKES!
