My 64 econoline runs well but the voltage regulator is not hooked up. Does anyone have a diagram of where the wires go or know where I could fine a diagram for it?
Voltage regulator not hooked up
bugman- Number of posts : 72
Registration date : 2011-12-17
Rayallen- Number of posts : 648
Re: Voltage regulator not hooked up
1st off Welcome to Vintage Vans. I love this site.
On the top right of your screen you should see a button that says search, Click on it and type in Wire Diagram and there are a lot of threads on this subject.
Heres a link
https://vintage-vans.forumotion.com/t26206-wireing-diagram?highlight=wire+diagram
Heres a link
Or is it unhooked because someone added a 1 wire alternator to the van and just left the old regulator there ?
Thanks for quick response. I checked the alternator, it is not just one wire exiting the case. It's obviously not the original regulator either, there's 3 wires not connected, I'll use this diagram and see if I can figure it out...after I determine if this is the correct regulator.
But the question is,,,,,,,IS IT CHARGING???
I'll check next time I'm out there. Remember, we just got this van 24 hours ago, I'm still compiling a "grocery" list of things I want to do (tune up, total brake job, fluid changes etc...). I'm comfortable with those jobs but when I saw the voltage regulator I was puzzled as it ran fine (for sitting 20 years)
You never know what you will find on these vans,,,,you could have a generator or even a Chevy Alternator on or a Motorola one or a Hot Rod one instead of the Autolite,,,,,,
