    2nd Gen steering coulmn length
    Eagle1
    Eagle1
    Number of posts : 144
    Registration date : 2010-09-18
    2nd Gen steering coulmn length Empty 2nd Gen steering coulmn length
    Post by Eagle1 Thu Oct 20, 2011 2:46 pm
    Hello all,
    Does any on know the steering coulmn length measurement from the top of the outer shell of the column to the end of the lower shaft on a automatic 2nd Gen coulmn? I am thinking of getting a coulmn from Ididit for the 200r4 conversion I will be doing this winter. If not I will be using the Lokar cable floor shifter, which one is easist on the pocket book.
    Thanks Eagle1
    Number of posts : 12245
    2nd Gen steering coulmn length Empty Re: 2nd Gen steering coulmn length
    Post by donivan65 Thu Oct 20, 2011 4:10 pm
    Eagle1
    Eagle1
    Post by Eagle1 Thu Oct 20, 2011 4:34 pm
    Donivan65,
    I just need the overall length 2nd Gen automatic coulmn.
    Eagle1
    2nd Gen steering coulmn length Stcolshiftdraw
    Post by donivan65 Thu Oct 20, 2011 5:42 pm
    The deal is, the steering wheel shaft is part of the van steering box,,,,in those other steering columns, it is part of their steering columns,,,,so you end up with 2 steering shafts that need to be cut and connected somehow,,,,,and what about the shifter,,,,,ours is below the steering box,,,,,theirs are above,,,,Van stuff is weird,,,,we got a column, a steering wheel and gear box ,and the shift shaft and levers,,,,,they are 3 separate systems and I think you want to squeeze them all into 1 shiny pretty unit,,,,,
    Post by G-Man Thu Oct 20, 2011 6:23 pm
    Eagle 1, I went with a floor shifter on the 64, and got my column from Ididit. Buy the time you cut the shaft and add the u-joint to put the two together I had to have the stardard 30" column w/tilt cut down 6 1/4 inches to make a column 23 3/4" to fit right.
    Eagle1
    Eagle1
    Post by Eagle1 Fri Oct 21, 2011 1:49 am
    G-Man,
    Was it a Lokar?
    This is the parts list Lokar gave me, Did you use a 10 foot Shift cable or 8 foot?
    23” 2004R Cable Operated Shifter Part No. COS6200RAM
    10’ 40 Series Cable Part No. 68209
    8’ 40 Series Cable Part No. 68200
    2004R Horizontal Dash Indicator Kit Part No. CIND-1727
    2004R Black Kickdown Cable Part No. KD-2700U
    Black Speedometer Cable Kit Part No. SP-1500U
    I will not have to change the coulmn if I go with a floor shifter.
    Eagle1
    Post by G-Man Fri Oct 21, 2011 3:53 am
    I haven't installed the shifter yet, but think I have the 10 foot cable
    Number of posts : 387
    Post by whopman Fri Oct 21, 2011 5:15 am
    I used the 8' on the 66 but I am running a th350 tranny.. Don't know where the shift lever is on a 200r but I think the trannies are the same length..
      Current date/time is Sun Nov 17, 2024 3:52 pm
