+42
kgdb
organ grinder
DannyDodge
Wookee
Hangtime
slimtronn
LiveWire64
back2thewoods
mcfly
64chevy
gotavan
mo_1040
wacko
PolarBear2
hywaychild
veefre
ViewMaster
46 posters
What are you up to?
RipVanArkie- Moderator
- Number of posts : 987
- Post n°476
Re: What are you up to?
Leaving in one hour for Jackson, TN to retrieve the 8door Econoline! I finally get to bring her home and into the herd!
Later,
Rip
2013 MidSouth Econoline Meet
1967 Econoline Pickup
1966 Econoline Supervan
DanTheVanMan- Commissioner
- Number of posts : 7900
- Post n°477
RipVanArkie wrote:Leaving in one hour for Jackson, TN to retrieve the 8door Econoline! I finally get to bring her home and into the herd!
Good luck Steve and be safe. We'll want to see lots of pic's when you get her home.....
- Post n°478
Dan your wheel and tire combo looks great,What coating did you use on the floor? Bill
- Post n°479
Bill,
I cleaned the interior really good and gave it a once over with Rust Encapsulator:
http://www.ecklerscamaro.com/product.asp?pf_id=749023&dept_id=122&cm_mmc=Froogle-_-Car+Care+%26+Tools+-+Paints-_-749023-_-X
Then sealed all the seams:
http://www.levineautoparts.com/3m08405.html
And for the coating I simply went with a "Brush-on Bed liner. It's kinda pricey online but you can get it at Walmart for $45 a Gal. and buy your own small roller while your there. I got 3 full coats from a gallon, front to rear...
http://www.pickupspecialties.com/Herculiner/Herculiner_brush_on_bedliner.htm
- Post n°480
Been really busy around the house, did get the timing, and "running bad" issue fixed...........I think. The monojet carb is a wierd creature to get adjusted right! Hopefully its adjusted right now, time will tell.
Should just put a Holley 8007 on it with an Offy manifold and some headers!
- Post n°481
Carb in the '68 crapped out yesterday, shaft going into the carb where the throttle linkage hooks up has side play and is letting gas flow out around it. At least it was nice enough to go out after Baker's. And I found it in the driveway when I was warming it up to lean it out a little. Thank goodness for a full time fan to help it evaporate and not have an engine fire the last time I drove it.
- Post n°482
Today is "demo" day for the parts van, the only things left to take off of it are the axles when I get down to them with the saws-all. Sad to see it die, but it has a lot of rust and 90% of the body panels are shot.
- Post n°483
Home with the 8Door Econoline!!! Extra body panels and misc parts out the tailpipe! Bringing home a 16x30 building this week from work (for freeeeee!!) to use for storage of the 8Door and the 67 Econoline and parts. Happier than Donivan with a sawzall in a Pik'n'Pull!!
Later,
Rip
- Post n°484
And that would make you a VERY HAPPY GUY!!!!
Kakster- Number of posts : 236
- Post n°485
Rip, How does one get a 15 x 30 building home? Sounds like one good sized storage shed, send in pics!
- Post n°486
Sounds like some bracing, jacking, and back the car hauler under it, a couple of red flags on the corners and away you go. INSTA-Storage.
- Post n°487
Dismantled... It's all woodframed on a slab. I'm leaving the slab at work! Replacing the siding and roof with metal and raising the wall height to 12' instead of 8'. Later, I'll add a full length lean-to on each side. This is not my future shop, just a dry place for my toys.
Later,
Rip
Later,
Rip
- Post n°488
Dropped my gas tank today...OH MY GOD!!!! I couldn't believe the crap in there!!!! After a good cleaning found about 6 pinholes in the bottom. Had my kid shake the gas tank with a bunch of small rocks in it to knock off some rust from the inside of the tank. Looks like most of it is thick varnish from old gas. Taking it with me to work to get it welded up tomorrow. Sender was... well it was kind of there. No screen to be found. I found a small brass piece that used to be the float. I think I'll replace the fuel line all the way up to the motor as well. The fun never ends...............
- Post n°489
WOW Kurt. You make me feel really lucky.. Somehow mine was spotless. Are we supposed to have screens in our filler neck or did that come to the auto world later in life?
- Post n°490
Pulled front end. Checked king-pins and sleeves, packed bearings this morning and took her in for a front end alignment this afternoon... Much better. Pulled my sterring wheel for the trip the the JY tomorrow. Hopefully I'll find a really cool new one that fits...
crazee- Number of posts : 331
Registration date : 2009-02-24
- Post n°491
going to the lumber store today to pick up plywood & some 2x4's. Finally going to build the platform for my futon mattress that's laying on the floor in back. LOL
Been driving the heck out of her. but want the bed done right for the up coming Van Slam in New Lexington, Ohio.
Besides, a spare tire makes a crappy pillow.
- Post n°492
wacko- Number of posts : 423
- Post n°493
Looking good Don. Its been a long battle and I'm glad to see the good guys won
- Post n°494
I changed all four shocks and finished my front brakes. I think next is to get all my dash lights working properly.
- Post n°495
Going to Rustorama tommorow a huge car show at the hollywood tavern in Salem,Or. Beer garden ,Vendors, tattoos,and more flyer says NO trailer queens.Should be cool guess there were couple hundred cars there last year .Bringing the van and a buddy of mine is bringing his early ford panel van he got recently and it is for sale I'll take pics. Bill
- Post n°496
went to rustorama yesterday lots of rat rods But this one was cool has a nasty sounding 440 in it. Bill
- Post n°497
If you want some cool ideas for your van check out the things the rat rodders are doing. They come up with some great stuff.
- Post n°498
Finally finished my wall and fence today! Maybe I can get back to work on the Handi now.
- Post n°499
- Post n°500
Working away on small details to make a weekend at the VAN SLAM in Ohio a comfortable one.
