    electric fan info
    Number of posts : 8769
    electric fan info Empty electric fan info
    Post by dix Sat Mar 26, 2011 10:18 am
    I got my van on the road last year about labor day week-end. 318/edelbrock manifold. edelbrock 4 brl. and a new alluminun rad i was stuck in a hiway traffic jam with no were to go. the van started running to hot . it has a factory fan. what should i be looking @ as far as a fan.?? electric?? if so what size ?? i know nothing about electric fans. i do not have a shroud on the van. it was a /6 and the shroud was to small. if i install a electric fan should i remove the stock fan all togather. or run both .or buy a differnt fan blade. thanks in advance...
    electric fan info Empty Re: electric fan info
    Post by Guest Sat Mar 26, 2011 12:31 pm
    Get a 3200cfm electric fan, measure the width of your rad and get a fan that will cover most of that width. Put it in front of your rad.. That way you can turn it on when you need it or hook it to come on when the temp reaches a certain level. I would remove your stock fan and get a flex fan that way you have a pusher and a puller. My 347 stroker never got hot not even in 115 degree weather.
    zbermen
    zbermen
    Number of posts : 60
    Post by zbermen Sat Mar 26, 2011 1:41 pm
    vanishingbreed is right. I use a pusher fan and works great in the stop in go
    traffic. Keeps from putting needless wear on the motor.I use a 16 inch
    pusher fans on all my Vehicles.It has the quick connects that mount on the side of the radiator and not those straps that go through the radiator.
    [url=electric fan info 00811][url=https://servimg.com/image_
    Last edited by zbermen on Sat Mar 26, 2011 1:43 pm; edited 1 time in total (Reason for editing : spelling)
    Number of posts : 1778
    Post by m1dadio Sat Mar 26, 2011 2:30 pm
    By far the most powerfull electric fan available is the 17" Toruas 2 speed fan or the 18" lincon mark VIII 2 speed fan from the mid 90's high output cars.
    Thats all I needed to control the heat at any speed in my V8 65 G van. There is a southern california hot rod builder and towing guy who designed a relay set up to run this fan.
    Theres a bunch of links for you to look at on this link.
    https://vintage-vans.forumotion.com/t12244-cool-down-that-engine
    Read the testimony on this link 10th window down
    https://vintage-vans.forumotion.com/t20536-keeping-it-cool#80450
    M1D
    Number of posts : 957
    Post by slowflapper Sat Mar 26, 2011 4:05 pm
    For heavy traffic on hot days I put in a 16" Hayden Automotive 3710 electric fan (available at summit and nearly everywhere else), it's 1500 cfm and pulls about 16 amps. I have it wired from the battery and switched with a 30 lighted switch so I can turn it on and off when I want it. It's set up as a pusher fan on front of the radiator, I replaced my OEM 5 blade mechanical fan with a Summit heavy duty six bladed fan, the summit fan was cheap and it moves a lot more air.
    A 16" electric fits nicely on the bottom of the radiator, I mounted mine low so it would push "fresher" air out of the air dam instead of recirculating hot air. What temp thermostat are you running? I put a 160 in mine since I live in GA and its ungodly hot here in the summer, that made a big difference as well.
    also, from what I remember the A100 charging system is only 40 amps total (or is it 60?), Id be real careful with what amperage fan you get so you don't let the magic smoke out of the wiring harness.
    The fan:
    electric fan info IMG00432-20100314-1037
    view from the top:
    electric fan info IMG00447-20100327-1356
    Summit 17" Heavy Duty Six Bladed Fan
    Part Number: SUM-G4920:
    electric fan info IMG-20100912-00012
    I mounted the switch in a piece of 3/4" angle iron and mounted it to the bottom edge of the dash so I didnt have to drill the dash, it's also easy to see the light in the end of the toggle when its lit, get the switches at any parts store.
    in this pic is middle left by the clutch pedal:
    electric fan info IMG-20110313-00256
    Post by Guest Sat Mar 26, 2011 6:06 pm
    I wouldn't get a fan with less than 2800cfm but I live in So.Cal near the desert.
      Current date/time is Sun Nov 17, 2024 3:39 pm
