Got my Clifford oerformance headers jet hot coated
Wow, those are beautiful.. can i ask where you had this done and how much it cost you? I have a set of headers for my gto I'd like to have re-coated
I got them done at jet hot coating in Arizona. They have more than one plant so there may be one nearer to you. These are triple coated inside and out lowering the header temp up to 400 degrees. It was $225.00 for both. I am going to have my entire exhaust system done including the mufflers for a nice uniform look that will also make the system last much longer.
StuNami- Number of posts : 437
Registration date : 2010-12-14
I just got a quote from them. Thanks for the info Mike.
you are quite welcome. You can't go wrong with Jet Hot Coatings
should have done the toenails too - nice headder.
no one can get close enough to them without fainting.Twinpilot001 wrote:should have done the toenails too - nice headder.
