Threw the tranny into reverse when I was shifting into 3rd going about 30mph. Yep, "clunk". Just wondering what to expect, moneywise to have that 4 speed taken apart and rebuilt? Got it going but it is making a very loud clunking. Rolls fine in neutral so thats why I'm thinking trans and not the rear-end. Any input is appreciated, Thanx-Don. Here's a link, I luv this truck. http://picturetrail.com/sfx/album/view/23515909
dmfonline
Trans? or Rear-end?
dmfonline- Number of posts : 27
Registration date : 2010-10-13
Trans? or Rear-end?
Re: Trans? or Rear-end?
Im pretty sure you broke a gear or something inside that tranny....Not sure on the repair cost...I think that varies widley depending on where you take it and wether or not you remove the tranny yourself..
Make it easy and swap over to a more durable 3 speed. I could possibly do some swapping of parts with you to make it work. The Dags are fragile so I ve been told. I ve only driven one a few times a short distance and its definitely weird.
Old Skool- Econoline Guru
- Number of posts : 1306
Dags are NOTORIOUS for weak!!!! aside the odd ball gearing setup. I will have two 64 conversions to do next, one will be taking out the Dag and putting in a 300 with an overdrive using that column, however I don't see it being available here for at least three months???.
Seriously, think you would be much better off with a good synchro 3 speed like Tim may be able to set you up with. Also, what rear end do you have and what gearing does it have,, if you have the little one and 4 hundred gears, it would be a good time to fix it all...
vic
vic
Thanx Vic, I really like the 4speed. Seems unique and is fun to drive. I really don't know if it was me that did something wrong or the tranny just malfunctioned. Either way I would like to get it fixed. Looks to be easy to remove from van but the repairing of it I don't know what to expect. Also thinking of just selling the van. It WAS great fun this summer.
Four speed is neet!!!! ~~~~~~~~~~ however,,????? I really don't know anyone who is good at manuals,, I have a killer connection for automatics. Keep in mind the 3 spd back up plan. If that is your truck there,, it really looks like a clean one!!!!! I am a little bit more committed to our trucks,, LOL... than selling one like that...
Every once in a while the Dag parts come up on E useless, but few and far between? Its a no brainer too easy to do, to drop it,,, and for your own curiosity, you can pull the top off and take a peak inside. Once there you may find yourself indeed going to the three speed. Let me know if it goes that way and we can work out a trade with a 3 spd column for you..
vic
vic
vic
vic
Mr Hill Billy- Number of posts : 213
Registration date : 2009-12-23
If you do convert to a 3 speed transmission with 3 speed column and linkage, you're better off keeping your old 4 speed column and linkage. The 3 speed stuff is dime a dozen (so to speak). That way, if you ever want to go back to a 4 speed, you'll already have the 'hard-to-find' stuff!
Seems like there was once talk of using a Granada overdrive tranny with the 4 column speed linkage a while back.
Decisions, decisions!
![Smile](https://2img.net/i/fa/i/smiles/icon_smile.gif)
I loaned a car to a 'friend' once and he called me up to say it broke down. He said is just stopped going into gear. I don't know what exactly he did, but when I removed the tranny, I found the friction disc sheared in two.
If you indeed did throw the tranny into rev while going forwards, the friction disc might be the weak spot.... if you're lucky. Nothing to do but take it apart and look.
Good luck.
Good luck.
It's out and been looked at inside.... Trashed .
