Then Come up to the shift Linkage ......
And Still Not Sure to do with the Kick Down ....
And the Dip stick Don't Fit Either !!!!!!
Digz wrote:Vanish , on the dipstick tube. I put one of those Lokar flex ones in my 700, hate the POC. If there is a decent way to bend ,torture or modify the steel one Id call it a last resort. Mine was junk to start with so I went aftermarket. The kick down cables are available in longer lengths if needed, I cant remember where I got mine for sure ,, probably Bowtie.
Digz wrote:It is slower to fill as you need a "should be supplied" adapter that you can hook up to a small funnel or something. That part doesnt bother so much as being hard to read the stick (maybe just old eyes). it's a nylon plastic dipstik and its just hard to see the color on it, and you have to wait awhile for the tube to drain enough to get a good reading to boot, And I have the short one! other than that they work fine and look good ! JMO
