My 61 pickup was running great... 144 six cylinder... Shut it off last week and let it sit a few hours.. upon restart it ran extremely rough and acted like it was on about 3 cylinders.. also made some terrible noises from the engine compartment....after about 5 seconds it smoothed out and ran fine? I only drove it a few miles since then and tonight when I started it it was running rough again, no noises... smoothed out somewhat but a steady miss remained...
I checked it out and # 5 cylinder wasnt hitting...checked the fire and the plug...good..
Checked the compression and there isnt any!
Im assuming that I have a stuck valve? The valves sounded noisy since I bought it, like they needed adjustment.. but wasn't on the top of my list since it isn't a daily driver... Any body have any ideas about releasing a stuck valve or how to remedy the situation?
Ive never had a vehicle do that before...runs fine when you shut it off and then go back later and have no compression?
Im guessing the first order of business is pulling the valve cover but Im concerned that I need a longer permanent repair even if I find a stuck valve.
HELP!
HELP!
