Hey guys...as seen in my intro post I have a 61 econo with a 200ci motor swapped in.
I have been working on it quite a bit for the last week trying to get it running. I have replaced: plugs, coil, starter, coil wire, starter relay (solenoid), battery and battery cables. I found the truck has an electronic ignition in it. Not sure what it is off of though.
First my spark issue. It is there sometimes and others it is not. When I turn my key to on my hot side of the coil is showing 7.7 volts? It had 12.7 prior but now I cant get it to show 12v...so clearly no spark at the plugs.
Fuel issue. I have tried everything to get fuel up to this thing. I have fuel up to the line that secures to the pump, turn it over and no fuel comes through the pump. I believe the pump is shot. I ordered a new one, and hopefully this will fix this issue.
I need some help with the spark issue and anything you can think of causing this old girl to not start. I was told by the previous owner it ran last summer and just needs brakes. I am frustrated beyond words because I just want it to start so I can get to the mechanical issues.
Any help or words of advice would be great...I am new to this econoline world. If someone is in the Minnesota are I am willing to compensate for their time to help me out.
Thanks, Jordan/Minnesota
