It’s always a big topic of conversation, but when the weather starts heating up its critical to find a solution. I have a 302/C4 that sits in a stock doghouse. The engine has less than 2,000 miles, 160 thermostat, 2-row (1” tubes) Champion aluminum radiator, belly pan, and a Flex-A-Lite electric fan. The temp gauge will stay in the 185-190 range most of the time, but under a load, or sitting in traffic it can get to 210. We all know that it is difficult to keep these things cool mainly because of the restricted airflow caused by the limited space between the engine and the doghouse, but the tighter space just means you need more “push.” Most of the electric fans everyone runs are between 2000-2500 cfm, which just don’t have enough grunt force to get the job done. I found a 16” fan on ebay made by FF Dynamics that has a 3600 cfm output that is built like a tank – it makes the Flex-A-Lite fan look like a toy. I installed it without a shroud because it covers 95% of the core without it. It draws some serious amps, so it must be installed with a relay and a 30-amp inline fuse. Mine is wired up to run with the ignition off so that it continues to cool for a couple of minutes when parked to draw down the heat load. I had it out for an extended run yesterday, and it was hot in So-Cal, but the temp gauge never got beyond 180 no matter how much load I put it under. When the fan kicks in, it will drop the temp by 10 degrees in a few seconds and actually turn off! With the old set up, once the fan kicked in, it would never shut off. It’s not a cure for a fundamentally bad cooling system, but if everything you have is working as it should, but still runs a little hotter than you think it should, give this one a try.
Jim
So-Cal
http://www.ebay.com/itm/16-INCH-FFD-CYCLONE-ULTRA-ELECTRIC-COOLING-FAN-3600-CFM-LOW-AMP-DRAW-SUPER-DUTY-/160746572676?hash=item256d3e0b84&item=160746572676&pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr
Jim
So-Cal
