you will like the difference the sway bar makes ! Bill
+8
12 posters
Back Yard 65???
- Post n°26
Re: Back Yard 65???
wylee- Number of posts : 920
- Post n°27
Re: Back Yard 65???
she DID clean up nice...............
whopman- Number of posts : 387
- Post n°28
Re: Back Yard 65???
Removed the doghouse today....it was put in with sheet metal screws and some kind of putty like JB weld...they really did a hack job...but it can all be fixed.
As for the sway bar...it won't fit the 66. the brake master and combination valve are too much in the way...don't know if the belly pan will fit either...
![Back Yard 65??? - Page 2 Doghou10](https://i.servimg.com/u/f23/15/13/14/73/doghou10.jpg)
- Post n°29
Re: Back Yard 65???
nightmoves pm'd you
- Post n°30
Re: Back Yard 65???
Great save!
Get it running and stopping, and you have some great barter material.
- Post n°31
Re: Back Yard 65???
GREAT FIND!! Lucky You - Keep the Possum parts - Nostalga # 1
savage- Number of posts : 2628
- Post n°32
Re: Back Yard 65???
As for the sway bar...it won't fit the 66. the brake master and combination valve are too much in the way...don't know if the belly pan will fit either.. Whopman if you want to sell the sway bar or belly pan from your 65. Let me know. Thank's Tom
- Post n°33
Re: Back Yard 65???
was tinkering with the 65 today....moved it to the back yard and discovered it has a 12 bolt rear end..
What is it worth and can you get a 2.73 gear set for it ?
