+4
SnarkyPoet
8 posters
    Steering fun
    Steering fun Empty Steering fun
    Post by Guest Thu Jan 21, 2010 12:40 pm
    I need your vast knowledge again friends,
    My Steering wheel has a lot of play. I don't expect anything super tight like todays cars, I realize it's old and the steering isn't that tight.
    But i can jerk back and forth a lot with no effect on the steering. I'm trying to figure out what parts might need to be replaced, but being this is my first vehicle i've really worked on, not so savy on possible problems.
    I purchased a steering damper - http://www.speedycarparts.com/sku/Dodge_A100_KYB_Steering-Damper_1964_1970_KYSS15345.html?ci_src=14110944&ci_sku=00024013820334064_7000262279
    But afterwards realized that doesn't effect the steering wheel play. laugh at me hahah
    Thanks again.
    Steering fun Empty Re: Steering fun
    Post by G-Man Thu Jan 21, 2010 12:45 pm
    On a Chevy steering box theres a screw on the steering box to tighten up the steering a little, not sure if there something like that on Mopar's
    Post by Guest Thu Jan 21, 2010 12:47 pm
    Hey G-man, Where might one find a steering box?
    Number of posts : 3046
    Post by RodStRace Thu Jan 21, 2010 12:51 pm
    There is a long procedure to adjust the steering box, but it may be time to rebuild.
    To adjust, here's a list of the high points:
    Find the center (rotate to each stop, counting turns, make sure it's in the middle).
    Loosen stop nut on steering box, then adjust slotted stud in center to specs.
    Tighten stop nut and check for binding. If adjusted too tight, it will wear parts inside and still not adjust out all the slop.
    Post by Guest Thu Jan 21, 2010 12:52 pm
    What should I expect to pay to have a shop rebuild the steering box?
    Thanks Rod
    SnarkyPoet
    SnarkyPoet
    Number of posts : 174
    Registration date : 2009-12-22
    Post by SnarkyPoet Thu Jan 21, 2010 12:54 pm
    Yes, the A100 steering boxes can be adjusted. I did Skooby's last fall and it was pretty painless. If you don't have a shop manual yet, it's worth the dough to get one. It has step-by-step procedures for almost everything in it.
    Post by RodStRace Thu Jan 21, 2010 12:59 pm
    Rebuild pricing varies on the general area, the shop and the box. I haven't had one done for 10 years, and that was on a 1940. That ran ~$350 if I remember. Like SnarkyPoet said, get a manual and give the adjustment a try.
    Also check the lube.
    Number of posts : 12248
    Post by donivan65 Thu Jan 21, 2010 1:06 pm
    1st, make sure the slop is in the steering box,,,,,rock the steering wheel and watch the pitman arm ,,,,if it is moving, the problem is downstream from the steering box like drag link, tie rods, kingpins or wheel bearings.
    Dantra
    Dantra
    Number of posts : 293
    Post by Dantra Thu Jan 21, 2010 6:53 pm
    I've got the same play. As mentioned above, check to see if you pitman arm is moving in conjunction with the movement of the steering wheel. If it is, you can basically move on to each joint in a ABC order and locate your play. Could be a combination of everything but I think this link is probably the main problem fixer
    http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=400083994422&viewitem=&sspagename=STRK%3AMEWAX%3AIT
    gravesj
    Number of posts : 34
    Registration date : 2009-02-11
    Post by gravesj Thu Jan 21, 2010 8:02 pm
    You beat me to it... Are these the correct drag links??? Has anyone bought one and put it on yet???
    Number of posts : 1148
    Post by jkr Fri Jan 22, 2010 6:38 pm
    these old steering boxes were a weak link. if your king pins were real tight you could rip a steering box out in no time. also trying to turn the wheel while stopped was hard on them as well. best to be moving while turning.
    i'm on box # 2 on my a and used 3 on my old van back in the 70's. i't the bearing balls at the bottom that wear out and start all the play. never seen a repair kit to fix one of these boxes. good luck. i have one spare and looking for another locally.
    Post by Guest Fri Jan 22, 2010 7:31 pm
    Anyone else swap out their large steering wheel for a small one like this dude.
    http://www.moparmusclemagazine.com/featuredvehicles/trucks/155_0305_1968_dodge_a100/index.html
    Number of posts : 1319
    Post by 67a 100 pickup Fri Jan 22, 2010 7:49 pm
    No thanks, I'm sticking with the original one.
      Current date/time is Tue Nov 26, 2024 8:13 am
