    1964 Falcon Vacuum Advance or timing troubles?
    graphikwerks
    Number of posts: 14
    Registration date: 2009-06-04
    Post by graphikwerks on Sat Jan 02, 2010 6:07 am
    I am trying to help my dad out again with his Ford. He relayed all of this information to me over the phone so I hope I get this correct enough for someone's advice.
    How can you tell if the advance mechanism is not working? The van seems to have a vacuum problem, it doesn't run well when cold and then runs better once warm. When it was warm, it seemed to run much better under higher RPM. Also, pulling any of the plug wires off at anytime didn't make it run worse than it already did. It misses like crazy.
    Now that it is so cold in Indiana the van won't fire and run at all. It backfires through the carb and seems to be out of time. The advance mechanism in the distributor seems to be completely stiff and won't move when pushed or rotated.
    What should we look for or test? The diaphragm is fairly new. Thank you in advance for your help.
    Number of posts: 22729
    Registration date: 2008-05-06
    Re: 1964 Falcon Vacuum Advance or timing troubles?
    Post by G-Man on Sat Jan 02, 2010 6:24 am
    Scott Has this van always hated the cold???? My 69 chevy has and it always starts hard when cold.
    This is off topic, but if you get a chance give us a picture of your Dads econo. I know hes been driving it for years
    Number of posts: 5627
    Registration date: 2008-05-12
    Post by donivan65 on Sat Jan 02, 2010 9:20 am
    The 1st thing is make sure the points are clean and adjusted,,,,,,nothing works right if the points aint right. Then get a timing light and and find the mark on the front pulley,,,,,,you run 3 checks from there,,,,,at idle, the mark should be at the number it calls be,,,,something like 4 degrees BEFORE top dead center,,,,,then you unplug the vacuum advance line and see that the mark does not change,,,,,then rev up the engine,,,the line should move (Advance more), away from the 0 ,,,,,then while revving, hook up the vacuum line, mark should move even more away from the 0 if both advance mechanisms in the distributor are working. Now some of the Fords have 2 vacuum lines on them,,,thats a different story. But another test is to hold the engine at a high RPM, pull off the vacuum hose, engine should slow down with hose off,,,,,speed up with line on. But the vacuum advance does not work at idle or have anything to do with starting, so you need to check other things if you have a problem in that area. And as usual, the POINTS ARE THE ROOT OF ALL EVIL!
    Post by donivan65 on Sat Jan 02, 2010 10:30 am
    Another test,,,,,when it is running, spray some carb cleaner into the carb,,,,,,see if that makes it run better or worst,,,,,,,
    graphikwerks
    Number of posts: 14
    Post by graphikwerks on Sat Jan 02, 2010 1:30 pm
    What if the mechanical part of the advance is stuck in the advanced position? Wouldn't the timing be off? My dad says he can't move any of the springs or parts around.
    I also think my dad should take a good look at the points.
    Post by donivan65 on Sat Jan 02, 2010 5:49 pm
    I don't think the truck will start if the centrifugal advance is stuck wide open,,,,,,those 3 advances are like 4 degrees of base timing,,,,maybe 12 more of centrifugal and maybe 12 more from the vacuum advance canister,,,,,thats why you check the timing 1st,,,,see if it is at around 4 degrees,,,,,then see if the centrifugal kicks its 12 degrees to make it 20,,,,,then hook up the hose,,,see if it adds its 12 degrees to make the timing about 30 degrees at high speed,,,,the springs and weights in the centrifugal advance, ( which you test by twisting the rotor and seeing if it moves and snaps back), might be rusted up,,,,WD40 them,,,,,and also see if the arm on the vacuum advance moves in and out moving the base plate that the points are mounted on....You might have other problems but we will get around to them as you keep providing us with more information,,,,,,
    Old Skool
    Number of posts: 490
    Registration date: 2009-06-13
    Post by Old Skool on Sun Jan 17, 2010 10:31 pm
    Check out this link later on timing issues. First of all, need to make sure youre carb and dizzy match. Will look that up also,, has to do with wrong carb installed possibly over the yrs????? Next and the basics are the dizzy. The advance plate needs to move freely, in order for either the springs and weights or the vacume canister to move it correctly?????????? if gummed up as usual, or broken springs??? it cant work right in the first place.
    Secondly, its impossible to correctly set the timing, UNLESS you firstly set the dwell correctly. Please ready in DWELL not adjusting the points with a feeler gauge,, LOL..
    A "DWELL" meter sets the points EXACTLY on the correct setting, and averages things like worn dizzy cam lobes, loose bearings/bushings, etc,, etc,, but sets the points right on the money,, no guess work like is the feeler gauge really sliding easily or too tight really????????????
    IF you use a timing light ( have no idea where mine has gotten to???), it doesnt acount for stretched chains, so I always set mine by ear... but again,, only after I set the Dwell. Basically, also, pull the dizzy and clean the advance plate, or replace it with a rebuilt unit,, pretty cheap actually. Then you can fight any missing engine issues or other problems, until then you will go in circles pulling your hair out,,, LOL.. will post the link later or loose this one, dratzzzz
    vic
    vic
    Old Skool
    Post by Old Skool on Sun Jan 17, 2010 10:34 pm
    here is some real good reading,,
    vic
    http://www.fordmuscle.com/archives/2000/03/timing/index.shtml
    Slowride
    Number of posts: 57
    Registration date: 2009-02-17
    Post by Slowride on Wed Feb 03, 2010 11:49 am
    I'll have to check again as the Alzheimer's may be kicking in, but the '64 should be a LOM (load-o-matic) system with no centrifugal advance, just vacuum.
    crayform
    Number of posts: 24
    Registration date: 2010-06-18
    Post by crayform on Fri Dec 03, 2010 4:30 pm
    Old Skool wrote:here is some real good reading,,
    vic
    Great link Old School. I've been having some timing issues lately and this will be a big help... Thanks!
      Current date/time is Wed May 16, 2012 3:04 pm
