I'm rotating my Edelbrock 1405 carb to help the throttle and kickdown linkage, but it puts the vacuum port for the PCV into the insulation of the doghouse. There's a plugged port on the other side of the carb. thats normally used for Power Steering. Can I use that one instead, or is it a different kind of vacuum?
Edelbrock PCV vacuum the same as the Power Steering vacuum port?
Scott- Number of posts : 1651
99% sure its the same. have 2 at shop, i will look in morning.
Thanks for checking j-man, I flopped it around tonight. I also stuck a 3" carb lift under it to get my cables to keep from running into the valve cover.
