    total newb question
    total newb question Empty total newb question
    Post by Guest Tue Aug 11, 2009 9:25 pm
    scratch
    So I'm about to get started breathing some new life into my 67. How can I tell if my six is a 250 or a 230? Please keep the flaming to a minimum, we all gotta start somewhere! LOL!
    total newb question Empty Re: total newb question
    Post by donivan65 Tue Aug 11, 2009 10:19 pm
    See if any of these codes show up on the engine tab next to the distributor hold down bolt,,,,,,,
    total newb question Van_en10
    Number of posts : 987
    Post by RipVanArkie Wed Aug 12, 2009 5:21 am
    Hey Donivan,
    What book is that taken from? That's just too handi!
    Thanks,
    Rip
    Number of posts : 7900
    Post by DanTheVanMan Wed Aug 12, 2009 7:26 am
    Fu_Manchu,
    You can also pull you casting numbers from your motor. And if you post them here we can look them up for you.
    They would be located opn the side of the block pass side behind the distr.
    total newb question Qr_cod10
    Post by donivan65 Wed Aug 12, 2009 9:45 am
    I RIPPED it out of this book,,,,,I don't have too much faith in castings numbers,,,,,they seem to use the same numbers on a 230 and 250 since they have the same bore size. I would try and take a spark plug out,,,,put it at TDC and put a wire or something in there to see how far down the piston goes, which would be the stroke,,,,,230 stroke is 3 1/4",,,,,250 is 3 1/2"
    total newb question Chilto10
    Post by Guest Wed Aug 12, 2009 12:34 pm
    2084F19
    Post by Guest Wed Aug 12, 2009 12:42 pm
    sorry about the last post, from my phone. Here is the info.
    casting number:2084F19
    Number stamped in by Distributor: F0121TCK
    I didn't see a tab next to the distributor bolt, there was just the stamped in number.
    Post by Guest Thu Aug 13, 2009 3:22 pm
    Well let me ask this wouldn't most tune up parts be the same between both engines? Then ill just check the stroke when I tear into it.
    Post by donivan65 Thu Aug 13, 2009 5:44 pm
    194/230/250 all look the same,,,,I would choose 250 unless parts started being wrong,,,,then go with the 230,,,,
      Current date/time is Fri May 10, 2024 2:02 pm
