by donivan65 Wed Oct 07, 2009 6:41 pm
The 1st problem is where do you mount the compressor???? Will it fit in the Doghouse,,,,,,can you run a pulley and belt to it? Then there is the Condenser,,,,,it needs to have air blowing through it,,,,,and it takes the hot air out of the cab and releases it normally in front of the radiator,,,,,as for the evaporator unit,,,,,you could just throw it on the floor or in back,,,,,just as long as it takes the heat out of the truck. So,,,,,it can be done, but it will take some work. I seen some old time air conditions sitting on the roof of some vehicles,,,,,,I guess they still need that compressor mounted on the engine for it to work.
