Air conditioning your van. Any tips or tricks??
Skulptorchaz
Skulptorchaz
Number of posts : 301
Post by Skulptorchaz on Tue Mar 08, 2016 3:47 pm
I am wanting to put an AC in my van and have talked to several AC companies (Vintage, Nostalgic, etc.) It seems like they have the stuff to do it but it is a "universal kit". Have any of you done this and do you have any suggestions? Tips? Tricks?
I want to put one condenser under the dash and a second one on the back of the dog house. They tell me the pump can handle both OK. My question is, where did you mount the pump?? High or low? Left or right? It seems a bit tight in there. Smile Did you have to do some creative mounts??
Thanks in advance.
Chaz
Number of posts : 11684
Re: Air conditioning your van. Any tips or tricks??
Post by donivan65 on Tue Mar 08, 2016 11:06 pm
I would say they make a compressor mount that fits above the stock distributor,,,,,,so you cant use a HEI unit,,,,,,a remote condenser with an attached fan would sit under the van like in back of the battery to handle the heat from your 2 evaporators,,,,,,,
Skulptorchaz
Skulptorchaz
Post by Skulptorchaz on Wed Mar 09, 2016 5:53 am
Thanks Donivan. That is an interesting set up. I doubt the pump over the distributor will work for me as I already have an HEI in there. I guess I will have to try to get more "creative" with the mount. I'd love to see pix of what other have done before I go "creating" a new mount.
Thanks again!
Chaz
Post by Twinpilot001 on Wed Mar 09, 2016 6:38 am
Look in the extensive web pages of "Vintage Air" also others for applications & installs. cheers
Skulptorchaz
Skulptorchaz
Post by Skulptorchaz on Wed Mar 09, 2016 4:29 pm
Good tip! Thanks Twin!
    Current date/time is Fri Feb 22, 2019 3:00 pm
