    turn signals
    turn signals Empty turn signals
    Post by Guest Thu Aug 06, 2009 12:50 pm
    I currently have no turn signals on my '65. The previous owner said they worked fine and then after sitting for a weekend they didn't work. Is there a fuse that could have blown for this or should I check wiring/turn signal switch? I've got a spare switch........
    mark in Portland oregon
    Number of posts : 655
    turn signals Empty Re: turn signals
    Post by 61econoline Thu Aug 06, 2009 2:09 pm
    i would check all the bulbs and sockets first make sure they are clean
    Post by donivan65 Thu Aug 06, 2009 2:41 pm
    It probably is the flasher,,,,,take a test light , turn the key on, pull out the flasher and see if you got 12 volts in one of the 2 sockets that the flasher came out of......if you got power, try another flasher,,,,like even out of another car,,,,,,no power,,,then check the fuse in the fuse block and then the hunt is on to find the short,,,,,,,
      Current date/time is Tue May 14, 2024 6:36 am
