    turn signals
    back2thewoods
    back2thewoods
    Number of posts : 842
    turn signals Empty turn signals
    Post by back2thewoods Thu Jul 09, 2009 7:20 pm
    my turn signals dont return, is there a cancellor available?
    Number of posts : 1778
    turn signals Empty Re: turn signals
    Post by m1dadio Thu Jul 09, 2009 9:29 pm
    What year?
    just one side dosn't cancel or both?
    M1D
    back2thewoods
    back2thewoods
    Post by back2thewoods Fri Jul 10, 2009 12:44 pm
    both, 1964
    Post by donivan65 Fri Jul 10, 2009 10:03 pm
    You need to pull the steering wheel off and check out the 2 plastic pieces that get the job done. Attached to the bottom of the steering wheel is the round CAM,,,,,it should have a nice square cut out in it. Then in the column is the cancelling arm,,,,,see that the 2 fingers are not broken off. If you need a whole switch, the 64-66 pickup can be made to work,,,,,,,
    turn signals Repair52
    turn signals Tsig_c10
      Current date/time is Mon May 13, 2024 7:28 pm
