First I must admit, I totally suck at working on vehicles having little experience and less patience. I am a large man with a bad back and lessening eyesight and can't dig around in or under my truck, or behind the dash without some difficulty.
Having said this..........
I believe that I have successfully wired my gen II signal switch though I still need to install a second flasher for the emergency warning.
Front tun signals illuminate in the "parking lights" position but go off when I turn the lights fully on. I am getting no signal action front or back.
To (maybe) complicate things I installed LED bulbs front and back, although the same problem does exist with the regular bulbs still in.
I thought that I might replace the existing flasher unit when I install the second one but the problem is that I CAN'T FIND THE FLASHER UNIT. I have followed the BLUE wire to the main harness but can't find it from there.....
Any input would be welcomed.........
Thanks ~Z~
Thanks ~Z~
