    Turn signals again
    Richie Rich
    Number of posts : 45
    Turn signals again Empty Turn signals again
    Post by Richie Rich Fri Mar 21, 2014 3:53 pm
    O. K. This time, for a couple of days when I pushed the lever up for a right turn signal the dashboard light lit up solid and neither front or back signals lit up. I checked the bulbs, they seem fine. Left turn signals worked fine. Now, today it's reversed. The right side works properly and the left side has the same symptoms. A solid light on the dash and the outside lights don't work
    Turn signals again Empty Re: Turn signals again
    Post by donivan65 Fri Mar 21, 2014 4:59 pm
    IF,,,,,,the arrow lights up in the dash then the turn signal switch is sending juice to it,,,,,so take the lens off the front,,,,,put on that turn signal,,,,,hook a 12 volt test light or a jumper wire to ground,,,,touch the base of the bulb, the socket and the frame of the light,,,,,see if you lost ground on one of those 3 places,,,,,Do the brake lights work?
    Post by donivan65 Fri Mar 21, 2014 10:04 pm
    if you was adventurous and wanted to check out the turn signal switch circuit,,,,you would go to the 2 connectors above the brake pedal and see what the wires are doing,,,,,dark green goes to the RR brake/turn bulb....yellow to LR.....light blue-LF dash bulb and turn signal....dark blue-RF.....white is power up from brake light switch.....purple is power from flasher....black is the horn......so take a voltmeter or test light and see if those wires are doing their job,,,,if they are,,,,problem is at the bulbs,,,,,
      Current date/time is Tue May 14, 2024 1:38 pm
